Originally Posted by po7553po OK here are the results from the test-
Test Parameter Result Additional info if available
IDLE SPEED CO 2.08% Greater than 1.20%
IDLE SPEED HC 778 Greater than 220 parts per million
HIGH SPEED 265 Greater than 220 parts per million
I dont know what they mean but hear they are.The car is a 1992 300 SL-24 with 195,000 miles.Never had test in Nevada before but passed emissions in Ct in 2011.Did head gasket 2 years ago.Thanks for the help.You guys are the most helpful people I have ever dealt with. |
Looks like you have a rich mixture which produce unburned gas as shown by the high CO results. This also influenced the high HC PPM reading.
You need a complete tune up; plug, cap, wires and on a 92 IIRC you can manually adjust lambda (fuel/air mixture) close to 50%. Worst case you my need to replace your O2 sensors and cats if HC is still above specs.
