Originally Posted by faisal-87 thanks, it was not normal to me, actually it disappeared after the car is fixed.
does this have a fuse somewhere but not in the normal fuses box? where can i find it? |
Glad you are up and running again, and thanks for keeping us updated, it may help other members
Most likely the OVP relay, (Over Voltage Protection) not under the air filter it is located beneath the windscreen on the LH side of the car under the large plastic cover, you will see the fuse on the top of it. Familiarize yourself with the location you may need to visit again
But it is a easy fix and will save you $50 in the future.
I presume the location is the same for LH & RH Drive cars?
