no start after a big long rainstorm - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 12-13-2012, 03:32 PM   #1 (permalink)
Date registered: Sep 2012
Vehicle: 1997 sl500
hi people,
new to this site and mercedes....
love my 1996 sl500, had it for a few months, but apparently it doesnt like rain.
we had a huge storm and it started during the storm and i moved it to higher ground. next morning no start....
so i took another car to work, returned that eve and she started up, ran fine. i allowed it to idle for about 15 minutes, drove around the block.
next morning no start. tryed the wait again, but no luck this time.
i have read about wd40 and hair blow driers but would love some leads as to where to start.
any suggestions?
thanks,
germanfan
germanfan is offline   Reply With Quote
Old 12-13-2012, 04:27 PM   #2 (permalink)
Poundy's Avatar
Date registered: Aug 2010
Vehicle: 1992 500sl Pano, 1999 CBR 1100XXxx Super BlackBird "The Beast", Jaguar X Type
Check battery first, you may have drained it with the no start issue. After starting it the next day you may have not run it long enough to get power back in.
I would then check all fuses, after that it would appear you need to find what the water as saturated.
Life begins at 240 KPH
Poundy is offline   Reply With Quote
Old 12-13-2012, 04:37 PM   #3 (permalink)
Vehicle: 1997 sl500
one suggestion i also got was crank position sensor, moisture issues with them. drivers side bellhousing follow the cable...gonna blowdry it
Old 12-13-2012, 06:31 PM   #4 (permalink)
tdoriot's Avatar
Date registered: Jul 2011
Vehicle: 1993 600SL, 1973 450 SL, 1998 SLK 230, 1968 Pontiac Firebird, 2001 Dodge Ram 4x4
Post
You know it's due to moisture intrusion. Take the cover off your computer coffin and make sure that doesn't have any water in it ! That has been a problem for some guys in the past. Also check any ignition parts for moisture. Im not sure if your car has individual coil packs or distributor caps. If it has caps, remove those and check for moisture. If moisture enters those caps, it will condense when it cools down and you get ether a grounded spark or cross firing. All that said, it's a water issue !
tdoriot is offline   Reply With Quote
Old 12-13-2012, 07:42 PM   #5 (permalink)
Vehicle: 1997 sl500
I'm new to this car and there is no manual available, where is the computer?
Old 12-13-2012, 07:47 PM   #6 (permalink)
SL BRABUS's Avatar
Date registered: Mar 2007
Vehicle: 2 SL with every Brabus mods available & Class A competition sound system
on the passenger side of the firewall of the engine.....
Horsepower: enough power to go from point A to point B
Torque: enough to get the car moving
0-60 mph: not in a rush
0-1/4 mile: about 5 minutes @ 2mph because no need to showoff
My SL R129 collection with pictures
SL BRABUS is offline   Reply With Quote
Old 12-13-2012, 07:47 PM   #7 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
Look at the area where the water drains down from the the windshield.
RKH is offline   Reply With Quote
Old 12-13-2012, 07:56 PM   #8 (permalink)
tdoriot's Avatar
Post
Assuming you have a left hand drive car, the computer bay is under a black plastic cover on the passengers side up near the windshield. You'll see an oblong over that I'd above another cover that has the 38 pin diagnostic connector. Check in that cavity, then take the cover off the aluminum computer coffin and make sure it's dry. That's a good starting point. Good luck !
Bookmarks
