Got any Hard Top install tips? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 11-28-2012, 09:19 PM   #1 (permalink)
retiringinmind's Avatar
Date registered: Sep 2007
Vehicle: 1990 SL500 6L AMG 103,000km
I've had my 1990 R129 SL500 AMG 6 litre for a number of years now. It's a great car, but every fall it turns into the pickiest beast on wheels. This year, it took us a half hour of messing with the hard top to get it to grab on all 4 corners and suck into position. Either nothing happened, or just the backs pulled in or just the fronts. I don't think it's a doors open or windows down issue, it's just getting it in the "right" position. It's easy to see where I think the back posts are supposed to sit, but you can't see the front posts and you are trying to support this beast of a top while my lovely wife is doing her best to assist. Very frustrating. So much so that she declared that was the last time we'll be doing that and will be selling it in the spring. I can't say that I really blame her. So, anyone figured out how and where to place that roof so it works every time? Even if we do sell, I want to be able to demo the operation to the prospective buyer without it taking a half hour! Any ideas appreciated.
retiringinmind is offline   Reply With Quote
Old 11-28-2012, 09:32 PM   #2 (permalink)
MercedesTheBest's Avatar
Date registered: Jul 2012
Vehicle: 1995 SL500, 2012 E550 2 Door Coupe, 2012 GLK350
normally i just put the rear pins into the holes and then the front hooks on the hardtop rest into the part above the windshield. when i push the button it normally works. pulling the rear down and the front sometimes needs a bit of a push down to grab. but normally it can just rest in the position, no need to hold it or fidget it in. sounds like maybe the car has been warped a little bit so it isn't 100% square anymore.
1995 SL 500 Mercedes Benz
2012 E 550 2 Door Coupe Mercedes Benz
2012 GLK 350 Mercedes Benz
2002 CL 500 Mercedes Benz - (sold)
1984 Camaro 5.0L High Output Chevrolet - (sold)
1982 CD 300 Turbo Diesel Mercedes Benz - (sold)
MercedesTheBest is online now   Reply With Quote
Old 11-28-2012, 10:08 PM   #3 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
The rear pins are a bit flexable and they can be bent some. Front ones are rigid.
RKH is offline   Reply With Quote
Old 11-29-2012, 01:55 AM   #4 (permalink)
Date registered: Feb 2012
Vehicle: 1995 BMW 530i, 1990 Mercedes-Benz 500SL, 2002 Ford Explorer EB V8 4x4
This is the guide I used when I first jumped into the R129 world...
-Rod
RRousta is offline   Reply With Quote
Old 11-29-2012, 09:21 AM   #5 (permalink)
Date registered: Dec 2010
Vehicle: 1994 SL600, 1989 Jag XJS conv, 13 Hybrid Avalon 11 Chev 1500
My experience ( with a hoist, pads for the rear spikes and a no rush attitude ) has gotten better, but I still use some front side to side adjustment.
After Klaus rebuild the cylinders, and I reinstalled them I got a better vision for the task. I spent some time carefully positioning the latch assemblies, both front and back and with both soft and hard top. My hard top rear tynes had been bent, so that was the first and easiest adjustment. My guess is that someone stepped on or dropped something heavy on the protruded metal flange while it was stored.
Sorry to hear about the wife edict, but I have experienced several myself and even after 49 years still trying to understand the politics of marriage!
SRHsl600 is offline   Reply With Quote
Old 12-09-2012, 11:06 AM   #6 (permalink)
Thanks for the information and tips. I think I was doing it right, so I'd best investigate the possibility of bent rear pins. That won't be till spring now..))
Old 12-09-2012, 01:44 PM   #7 (permalink)
RKH
RKH's Avatar
Try to put something thick like a roll of paper tower in between so that the HT can rest on it while you move it around to 'align' the pins to the holes without scratching the paint.
Old 12-09-2012, 01:52 PM   #8 (permalink)
Date registered: Jan 2010
Vehicle: 1997 SL500, 1974 Triumph GT6, 1984 Citroen 2CV, 1953 BSA Bantam D1
I got myself into a bit of a mess last time I fitted my hardtop because my helper and I allowed the front pins to touch down first, and before I knew it the roof was stuck at the front and still up at the back. It needed my manual release tool to get it free. So as the video says 'back first, then front'.
Steve6 is offline   Reply With Quote
Old 12-09-2012, 02:05 PM   #9 (permalink)
RKH
RKH's Avatar
Yes, put that roll of paper tower on top of the windshield to prevent the front pins from hitting before the rear.
Old 12-09-2012, 06:57 PM   #10 (permalink)
SW23185's Avatar
Vehicle: 2001 SL500 / 2004 Dodge Ram 3500 HO CTD / 2010 Subaru Outback
In the five years we owned our SL with maybe 2-3 installation/removal cycles per year we never had an issue - it seated first time, every time without any drama. It was surprisingly forgiving, which makes me wonder if something's not quite right for these cars where it's problematic, as in latches aren't in their correct positions, mechanisms aren't lubricated, batteries aren't charged, pins/tabs bent, hydraulic fluid low, etc.
I would lift one side of the hard top and my wife would lift the other, but before we started we would review the process. We typically did a dry run (or two) with an imaginary roof between us to make sure each of us knew what was going to happen and when.
Here was our process :
Lower the soft top and let the cycle complete
Put heavy blanket on trunk making sure that the rear sockets are clear.
Roll hard top cart up to rear bumper in proper orientation (inside of hard top towards car).
Count 1-2-3 then lift hard top straight up with tail down
Count 1-2-3 then rotate hard top 90 degrees into correct orientation
Count 1-2-3 then walk forward to position hard top over car
Count 1-2-3 then lower hard top straight down, making sure rear tabs go into sockets
Verify that front pins are also in sockets
Press/hold the button and let the system cycle
Inspect to make sure that everything was OK
Good luck!
SW23185 is offline   Reply With Quote
Bookmarks
