1995 SL500 Climate Control - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 11-15-2012, 10:01 PM   #1 (permalink)
Date registered: Nov 2012
Vehicle: 1995 SL500-129
Location: Blackheath, in the Blue Mountains NSW Australia
Hi all,
I am new to the forum and this is my first post.
I have a 1995 sl500 100,000 km in show room condition. The problem I am having is when I put the air con on, I get hot air out of the two side vents and unless I press the blueg button in the center vent the air will be hot.
If I switch off the two side vents I get cold air out of the center main vent, but it seems like cold air comming over hot air. Please help.
Thanks, Ozzie Rob
Ozzie Rob is offline   Reply With Quote
Old 11-16-2012, 08:16 AM   #2 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
Have you try the RED button ?
RKH is offline   Reply With Quote
Old 11-16-2012, 03:15 PM   #3 (permalink)
Hi RKH,
Yes I have tryed the red button and that makes hot air come
out of all vents.
When I hit the blue button I get cold air from center vent and hot from sides.
Old 11-16-2012, 03:54 PM   #4 (permalink)
RKH
RKH's Avatar
Red button ON routs air through the heater core to the center vent.
Blue button ON routs outside Air to the center vent.
Both are for overridding the automatic climate control ssystem and direct cold/hot air to the center vent only, and has nothing to do with the side vents.
So leave them both OFF for automatic operation.
In automatic mode, the system controls air flap/doors to blend cold/hot air to the desire temperature, and those air comes out of both side and center vents (unless they are shut off by the thumb wheels).
From what you said, seem like you are getting hot air all the time, no matter AC is ON or OFF. Chances are you have a vacuum leak that the (vacuum operated) blending air flap door is stuck on routing Hot air only.
Old 11-16-2012, 08:03 PM   #5 (permalink)
Any suggestions as to where I should start looking?
Also, I should add that I am in Australia and it is RHD.
Old 11-17-2012, 10:54 AM   #6 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Start with checking the vacuum distributor, located in the module compartment.
It is known to crack around the ball bearing plug.
( Pull tubes with a 7mm open wrench.)
Also the vacuum reservoir.
It will help if you have a vacuum hand pump.
One indication is that the vacuum pump runs on and off for extended times.
Regards
aam.
aam is offline   Reply With Quote
Old 11-17-2012, 01:09 PM   #7 (permalink)
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Originally Posted by Ozzie Rob View Post
.... I get cold air from center vent and hot from sides.
I had the same symptoms on a W124 and it was caused by faulty mono valve. I don't know if R129 has the same mono/duo valve. It maybe worth checking if it does.
edcarls is offline   Reply With Quote
Old 11-17-2012, 03:10 PM   #8 (permalink)
Hi all,
Can you tell me where the module compartment is.
Thanks
Old 11-17-2012, 04:03 PM   #9 (permalink)
Hi all,
I guess what I really need to know is where it is and how to get to it.
Thanks,
Ozzie Rob
Old 11-17-2012, 06:45 PM   #10 (permalink)
aam
aam's Avatar
Hi all,
Thanks
It is located in the right engine corner by the hood hinge.
Six screws, lift the panel, and you are in.
Regards,
aam.
Bookmarks
