M113 Crankcase Vacuum Hoses and Intake Manifold Warning! - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 07-10-2012, 01:21 PM Thread Starter
buddha dean's Avatar
Date registered: Sep 2011
Vehicle: 1999 SL500
Originally Posted by lynns View Post
What is a 722.6 trans RST?
We usually use RST = Roadster Soft Top.
My mistake - I meant "rumble-strip" noise - I confused my terms. It occurs when the tourque converter switches to lock-up mode - when the actuator valve gets worn, the pressure in the lockup circuit is insufficient so it causes slippage of the lockup plate in the torque converter. This is a well documented problem on the Mercedes Sprinter, which uses a similar transmission (but the Sprinter uses the lockup for all gears, not just 5th gear like in the 722.6 - so the rumble strip noise occurs through all gears).
Superior transmission maxes a repair kit for this issue:
http://www.superior-transmission.com...age.cfm?ID=199
In my car it only occurs while in fifth gear when the RPM is around 2000 when using using light throttle going from coast to accelerate (happens between 65-75). The noise lasts for approximately 1/2 - 1 second, but it is obvious.
I replaced the Tourque converter lockup solenoid thinking that it was the problem, to no avail.
Last edited by buddha dean; 07-11-2012 at 06:27 AM. Reason: add link to repair kit
buddha dean is offline
post #12 of 25 (permalink) Old 07-10-2012, 07:17 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 171 Post(s)
Originally Posted by RKH View Post
That's what Albert (aam) usually say about other things too
Ray my friend,
The laws of similarities.
Regards,
aam.
aam is offline
post #13 of 25 (permalink) Old 07-11-2012, 06:28 AM Thread Starter
Vehicle: 1999 SL500
Here is a photo of my temporary foil duct tape vacuum leak repair lending truth to the statement "all you need in life is duct tape and WD-40" (I was quite surprised to see the AMG sticker on the intake)
post #14 of 25 (permalink) Old 07-11-2012, 10:01 AM
Moving On
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Silver
Quoted: 9 Post(s)
Air Intake Manifold vacuum hose
Scary! but it sounds like >100K miles.
Please read //pointedthree. com/disc/forums/showthread.php?tid=19288&mid=201161
The best price is for a used low mileage eBay M113 Intake Manifold p/n 1131400301 , 1131400701 , 1131400801 ($1350.00 MSRP) and misc. parts like the gaskets, etc.
MERCEDES BENZ INTAKE MANIFOLD WITH FUEL RAIL INJECTORS 1131400301 | eBay at $279.95
lynns is offline
post #15 of 25 (permalink) Old 07-11-2012, 01:00 PM Thread Starter
Vehicle: 1999 SL500
That is actually a good price. Parts.com has it for $972.
It is much lighter than it looks (magnesium alloy)
My total costs for the repair were under $40 excluding my time of course!
post #16 of 25 (permalink) Old 07-11-2012, 01:21 PM Thread Starter
Vehicle: 1999 SL500
Scary!
//pointedthree dot com/disc/forums/showthread.php?tid=19288&mid=201161
I love the part about the dead mouse - maybe he was just trying to stay warm!
I did forget to mention disconnecting the hose completely does set the CEL, and has to be cleared.
post #17 of 25 (permalink) Old 09-27-2012, 09:08 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 293 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
sorry to bring this post back up, but I was talking to Buddha Dean in person yesterday (It turned our his office is next door to mine... small world!)
looking at these picture, it seems like its possible to tap a thread in the Mg alloy, and install a barb end, that you can slip a regular hose on... problem is you still have to remove the manifold to do that... as there is not enough clearance to place the tap upside down in there...
I will look at my ML430 this evening to see if it can be done without removing the intake...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is online now
post #18 of 25 (permalink) Old 02-12-2013, 07:37 PM
Moving On
lynns's Avatar
Quoted: 9 Post(s)
For the R129.068 chassis and the M113.961 engine please consider the following Intake Manifold p/n's
MB p/n A113 140 03 01
MB p/n A113 140 07 01
MB p/n A113 140 08 01
Pierburg p/n 72267101
Pierburg p/n 72267104
Pierburg p/n 72267106
Note: add two new secondary air valves at $225 each, because the old ones will not come off the old manifold, or they will break in the attempt.
Intake manifold tubing to electric changeover valve - is shown in the EPC as a separate p/n A 0002760030 , available by the meter. Note: you cannot replace the tubing without major surgery.
Or just buy one with all of the attachment parts from eBay for about $400.00.
lynns is offline
post #19 of 25 (permalink) Old 02-12-2013, 08:24 PM
Moving On
lynns's Avatar
Quoted: 9 Post(s)
I was getting an Oil Change today at my favorite Indy and noticed five old Intake Manifolds in there trash pile and it prompted me to ask questions. To find out that they have NEVER had to replace a V8 113 Intake Manifolds. All of the old Intake Manifolds where six port. From 320 and 350 V6 engines. He showed me one that had it's Magnesium backside blown out possibly due to a back fire. He said that most of the V6 Intake Manifolds had broken outside plastic vacuum actuator air flap lever that open and close the internal flaps/baffles. >$2,000.00 expensive repair.
See attached PDF.
See the picture of a p/n 2721402401 C350 CLK350 E350 GLK350 ML350 SLK350 R350 Intake Manifold w/ External Plastic Air Flap Lever and External Aluminum Air Flap Lever (repair kit)
Name:	2721402401 Manifold Air Flap.JPG
ID:	495580   Click image for larger version
Name:	C350 R350 E350 Air Flap Lever.jpg
SinSL likes this.
lynns is offline
post #20 of 25 (permalink) Old 10-29-2014, 12:17 AM
Quoted: 99 Post(s)
Bumping this back up from the dead. If someone were to encounter the same problem, or just have a leak occur in the vacuum hose too close to the manifold to be able to remedy with a splice, is there any reason why one could not just tee off of another vacuum line to provide for the manifold flap switchover valve?
brauhaus is offline
