Manual top operation - Page 3 - Mercedes-Benz Forum
post #21 of 22 (permalink) Old 08-07-2012, 09:36 PM
tdoriot's Avatar
Date registered: Jul 2011
Vehicle: 1993 600SL, 1973 450 SL,1982 380SL,1998 SLK 230, 1968 Firebird, 2001 Dodge Ram 4x4,2005 Ford Escape
Quoted: 414 Post(s)
Post
If you swap your 129 for a 107, you'll have your wishes ! They are all manual with a few exceptions for a very expensive conversion
tdoriot is offline
post #22 of 22 (permalink) Old 08-08-2012, 08:31 AM
Supporting Vendor
TopHydraulics's Avatar
Date registered: Sep 2010
Vehicle: 03 SL Kleemann, 08 R320CDI, 97 SL320 pano top, 00 ML320
Quoted: 62 Post(s)
Converting to manual operation? Problems with early model years...
Originally Posted by larrynh View Post
Hi ,
I'am in NH with a 1990 500sl . do you have any pic of what you did? My top will
not go up so I would like to make it easy to do manually Thanks for your post
Larry
Larry,
I would strongly advise against conversion to manual operation, unless you absolutely cannot afford having the cylinders rebuilt. Manual operation eventually wears out the locks (and it is easy to damage the trim pieces around the locks when you use the soft top tool a lot), plus you risk damaging your canvas around the tonneau cover hinges. Keep in mind how much value you are adding to the car by fixing the top cylinders now, as opposed to going down the road where you have to find replacement locks later on.
On early model years, you may have to take up to eight cylinders out in order to facilitate manual operation. The reason is, the piston seals can swell up very tight and eventually make it next to impossible to move the locking cylinders and the tonneau cover lift cylinders manually.
Please see the following instructions on our website's FAQ page on how to lock your top without cylinders in place: http://www.tophydraulicsinc.com/maunuallockhardtop.pdf
Hope this helps,
Klaus
Top Hydraulics | Rebuilt Convertible Top Hydraulic Cylinders - Top Hydraulics, Inc
Top Hydraulics, Inc
Upgrading/rebuilding hydraulic cylinders, pumps and valves for ALL Mercedes convertibles and some 30 other brands
If you like my contributions, please reference Top Hydraulics and/or www.tophydraulicsinc.com in your response, and it will make Top Hydraulics more popular with search engines.
Happy with our services? Please let forum readers know!
Hydraulic system diagrams and DIY instructions:
http://www.tophydraulicsinc.com/en/c...y-instructions
TopHydraulics is offline
manual operation of roof slimsol R170 SLK-Class 1 05-07-2011 03:26 PM
broken manual operation for sunroof donkshophorse W140 S-Class 0 03-03-2011 07:35 AM
Help with manual roof operation on 93 SL 4benzes R129 SL-Class 5 10-15-2010 10:15 AM
DICE d2b operation? Manual? Don Vito V Audio & Telematics Forum 3 04-25-2010 09:17 AM
Manual roof operation pilotvfr R170 SLK-Class 4 08-11-2008 11:07 AM
