gurgling sound in gas tank?? - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 04-29-2012, 10:53 AM Thread Starter
~BANNED~
Date registered: Feb 2010
Vehicle: 1995 sl320
Quoted: 2 Post(s)
anyone know what can cause this? i hear gurgling/boiling/flooding sound in my gas tank towards the passenger side of the gas tank
benzdog is offline
post #2 of 15 (permalink) Old 04-29-2012, 05:01 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 172 Post(s)
Gurgling sound?
Did you provide mouthwash? Haha.
Check the vacuum pump for leaks.
Regards,
aam.
aam is offline
post #3 of 15 (permalink) Old 04-30-2012, 10:39 AM
560sec944's Avatar
Date registered: Jun 2010
Vehicle: 1999 SL500, 2004 CLK500, 2006 Cadillac SRX
I had the same issue in a Porsche 944 - I believe it is the check valve in the tank - it should let air in when the gas is being used (when running) to displace the volume of used gas with air. If the check valve is stuck, then you are drawing a vacuum.
Unlike any other.
560sec944 is offline
post #4 of 15 (permalink) Old 04-30-2012, 10:55 AM Thread Starter
~BANNED~
Vehicle: 1995 sl320
Quoted: 2 Post(s)
thanks on the help guys. how do i go about checking it and is it hard to do? i also hear pressure when i open the gas cap sometimes.
also is there a diy somewhere?
benzdog is offline
post #5 of 15 (permalink) Old 04-30-2012, 06:26 PM
aam
aam's Avatar
Quoted: 172 Post(s)
The valve is located under the car, over the diff.
Very hard to see.
This is a combination valve, it is set for pressure and also vacuum.
If this valve goes bad, some people had to replace the gas tank.
As the vacuum collapses the gas tank.
Regards,
aam.
aam is offline
post #6 of 15 (permalink) Old 05-08-2012, 12:09 PM Thread Starter
~BANNED~
Vehicle: 1995 sl320
Quoted: 2 Post(s)
anyone with pics?
benzdog is offline
post #7 of 15 (permalink) Old 05-09-2012, 08:05 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 303 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
aam.
o_O
never underestimate the force of air pressure...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #8 of 15 (permalink) Old 05-09-2012, 08:33 AM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 484 Post(s)
Yeh, I recall some member here posted a picture of his collapsed gas tank a while back
RKH is offline
post #9 of 15 (permalink) Old 05-10-2012, 12:16 AM
Date registered: Jan 2010
Vehicle: 1997 SL500, 1948 Rover 75 P3, 1984 Citroen 2CV, 1953 BSA Bantam D1, 1966 Velosolex Moped
Quoted: 21 Post(s)
Very hard to see.
Regards,
aam.
Just wondering - as a stop-gap repair, if the OP fitted an aftermarket filler cap with a slightly modified (ie less-than-perfect) rubber seal, the tank presumably wouldn't develop a vacuum but a) Would the car run OK? b) Would it be dangerous with say half a tank of fuel? I'm not necessarily recommending it to anybody, but it might be an alternative to a big repair.
Regards
Steve
Steve6 is offline
post #10 of 15 (permalink) Old 05-10-2012, 08:39 AM
RKH
RKH's Avatar
Quoted: 484 Post(s)
If the gas cap 'leaks' you will get a CEL, and may eventually ruin your O2 sensor.
RKH is offline
Kicking sound under windscreen washer tank ahm09 W220 S-Class 5 03-12-2011 08:38 AM
Tires and gurgling sound benzmoy W163 M-Class 2 12-09-2010 02:04 PM
Gurgling in the tank DP W201 190-Class 11 06-01-2009 09:18 AM
Gurgling from radiator overflow tank quidam W163 M-Class 3 09-18-2007 01:46 PM
sub install, getting sound through trunk with gas tank in way merk em Audio & Telematics Forum 7 05-13-2003 11:35 AM
