Other than oil changes, what fluids and when do they need refreshing? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-01-2012, 08:04 AM Thread Starter
lazz's Avatar
Date registered: Feb 2008
Vehicle: 2001 SL500 AMG
Quoted: 25 Post(s)
The title says it all. I ask because my car only has 14,000 miles and it sits in the garage and only comes out when it's sunny. Brake flush? Coolant flush? What else? Thanks ahead for the info.
lazz is offline
post #2 of 6 (permalink) Old 02-01-2012, 12:59 PM
Date registered: Dec 2010
Vehicle: 94 SL600, 89 Jag XJS conv, 85 Daimler Princess, 97 993 63 Avanti 16 Lincoln MKZ hybrid 16 Silverado
Quoted: 18 Post(s)
oxidation,debris, heat, fluid cycling are cumulative, but slow. Decades ago coolant was short. brake fluid, hydraulics, hypoid were very long. All the chemistry is better and more stable. I would worry more about stale gas in the tank!
When Klaus rebuild the soft top cylinders the hydraulic fluid I replaced was dark with a sludge about 3mm thick!!! 17 years of sediment?
SRHsl600 is offline
post #3 of 6 (permalink) Old 02-01-2012, 01:50 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
If it's my car, I'd drive it "vigorously" for a few hundred miles then have anything fluid replaced then go back to hibernating mode. That is another 14K miles by the year 2023.
mbvis is offline
post #4 of 6 (permalink) Old 02-01-2012, 02:53 PM Thread Starter
lazz's Avatar
Quoted: 25 Post(s)
Thanks for the advice. I'll do just that.....drive it "vigorously" for a few hundred miles, change all of the fluids then, like always, drive it once in blue moon. Chances are I'll probably die of old age before the car hits 25k. Thanks again.
lazz is offline
post #5 of 6 (permalink) Old 05-14-2012, 07:46 PM
Date registered: Nov 2011
Vehicle: 97 S500coupe. 97 sl320 2000 Corvette 1999 V star 650 Classic
Quoted: 2 Post(s)
Changing fluids
Another opinion! I have a 2000 Corvette Convertible that I ordered new in 99. It was delivered in Sept of 99. Today the car has 17,000 miles - 3,000 of which was driving it from Chicago to Calif a few days after 9-11 (could not fly). Te car has had the oild/filter changed (Mobil1) every 24 months. The coolant has been changed once. All other fluids are original. The car spends it's time in my climate controlled shop under a car cover. I keep it connected to a battery tender and make sure to drive it once a month. It looks and drives like a new car. My 97 SL320 on the other hand has 136,000 miles. GM does not recommend changing the brake fluid, six speed transmission or differential and with my low miliege I see no reason to change them. On the other hand - on my 97 SL320 and 97 C140 I adhere religiously to the schedule suggested by Mercedes.
Jan
Jre32 is offline
post #6 of 6 (permalink) Old 05-14-2012, 09:57 PM
JackBGood's Avatar
Date registered: Mar 2011
Vehicle: Y2K SL320
That's funny. I've always been told to change the brake fluid every 2-3 years, regardless of milage, because of the fluid's inherent moisture draw.
I know that DOT 5 supposedly draws less moisture than the older formulas, but still...
Jack
JackBGood is offline
DIY Thread need some refreshing 900$sel W126 S,SE,SEC,SEL,SD,SDL Class 7 06-30-2010 02:05 AM
Refreshing the Engine AGB R129 SL-Class 17 02-24-2008 03:55 PM
Instrument refreshing mckellyb W126 S,SE,SEC,SEL,SD,SDL Class 4 11-26-2007 06:28 AM
cd changer refreshing possible? berk R170 SLK-Class 7 02-12-2007 06:21 PM
Refreshing Headlights ct_thetinman W126 S,SE,SEC,SEL,SD,SDL Class 9 09-30-2006 12:17 AM
