Rear rotor removal on R129 - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 11-18-2011, 03:03 PM Thread Starter
Date registered: Nov 2009
Vehicle: 300 SL
I am stumped. I tried to get the rotors off to replace them but the old rotors wont budge. Do I need to take off the axle bolt and if so, what size(in mm) do I use? If not, what can I do to get them off. I have pounded on them with mallets and tried to pry them, all to no sucess. Any help would be appreciated.
dinodbl is offline
post #2 of 19 (permalink) Old 11-18-2011, 04:01 PM
Date registered: Aug 2008
Vehicle: 1992 190e 3.6 amg 1995 c220 1994 c220 1998 sl600 1992 300se 1972 450sl 2005 suzuki drz400sm
No you don't need to remove the axle bolts. I remember the first time taking my rear wheels off I had the same issue. Just keep beating on them until they come off, if that doesn't help have a larger stronger friend try. They will come off eventually, they rust to the wheel hub and suck trying to remove.
DUFFS3169 is offline
post #3 of 19 (permalink) Old 11-18-2011, 04:12 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 396 Post(s)
Be sure to remove the one Allen bolt that holds the disc to the hub (and of course, the calliper).
Spray around the joint with the hub with an easing spray, and start whacking the old disc with a hammer whilst trying to pull it off.
Don't worry about really whacking the old disc as hard as possible, you are replacing it, in fact the harder you whack it, the quicker it will come off
aam (Albert) will love this advice
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #4 of 19 (permalink) Old 11-18-2011, 06:23 PM
Date registered: Jun 2006
Vehicle: '06 E500, '99 ML430 & '07 SL65 AMG
Quoted: 64 Post(s)
Get a 3 legged puller. That will do it.
sgaar is offline
post #5 of 19 (permalink) Old 11-18-2011, 06:37 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 172 Post(s)
Ehmmm.
Is the parking brake on?
On the other side of the rotor assebly there is a hole.
In order to loosen stick a screwdriver in and spin the adjusting screw.
Don't even think to remove the center bolt.
You will be a very, very sorry man.
Regards,
aam.
aam is offline
post #6 of 19 (permalink) Old 11-18-2011, 07:08 PM
silarrow's Avatar
Date registered: Oct 2009
Vehicle: 2000 :W220 -2002: W203 - 1986 W201: 16v Nam,16v Euro- 2002:SL500 Silver Arrow.2002:Avalanche-
Quoted: 32 Post(s)
Originally Posted by aam View Post
Ehmmm.
Regards,
aam.
Hehehe.. I do like your comment . watch out for E brake and try using fresh COKE to loose the rusty stubborn dish..works for me every single time .
The German mind has a talent for making no mistakes but the very greatest
silarrow is offline
post #7 of 19 (permalink) Old 11-18-2011, 10:27 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 295 Post(s)
Fresh Coke. Ive heard of that for battery terminals but never tried it on rust. Another one I just heard for rusted bolts was a little heat and candle wax. Allegedly the wax wicks right into the joint. Never tried either of them, Im just the rumor spreader.
roncallo is offline
post #8 of 19 (permalink) Old 11-18-2011, 11:55 PM
patfarrell's Avatar
Date registered: Jan 2007
Vehicle: 2001 SL500
heat it with tourch and hit it . it will pop off
patfarrell is offline
post #9 of 19 (permalink) Old 11-19-2011, 01:40 AM
JackBGood's Avatar
Date registered: Mar 2011
Vehicle: Y2K SL320
Fresh Coke works wonders on rust, but you usually have to let the part soak in it for a while. Put a rusty bolt in a glass of fresh (un-opened) Coke and let it sit over night. I can practically garantee you that the bolt will be spanking clean in the morning.
Now, think about what this stuff does to your insides when you drink it...
Jack
JackBGood is offline
post #10 of 19 (permalink) Old 11-19-2011, 04:45 AM
Date registered: Apr 2008
Vehicle: 1991 300SL
I'd just second what has been said but to summarize:
Do NOT remove the wheel bearing nut.
DO make sure you've removed the allen on the front of the disc
DO make sure you have released the e brake and backed it off at the adjuster
DO spray some penetrating oil between the rotor and hub (PB blaster is good stuff!)
Do heat it if you have a torch (but DO NOT ignite the penetrating oil!)
Finnally, whack it out toward the edges working you way around it with a short hanndled 5 lb sledge. Whack it HARD. It will pop off.
Zachmac
2009 R350 (mom's hauler)
1991 300SL (soon to be oldest son's cruiser)
2004 S55 Klemmann mods (just sold, looking for E63 replacement, dad's haul asser!)
Zachmac is offline
    Rear Brake rotor removal 300TD1984 W123 E,CE,D,CD,TD,TE Class 5 03-03-2010 12:11 PM
    ### HELP ### Rear ROTOR Removal hifeverz R129 SL-Class 5 10-16-2006 09:49 AM
    1999 ML430 rear rotor removal JAD W163 M-Class 12 10-11-2005 06:00 AM
    Front & rear rotor removal...... valleyboy3000 R170 SLK-Class 7 09-14-2004 12:22 AM
    Rear brake rotor removal alex lynch W163 M-Class 5 11-17-2002 08:25 AM
