Loud droning noise w/ hardtop on between 50-60 mph - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-24-2011, 06:48 AM Thread Starter
Date registered: Oct 2011
I recently purchased a 1991 300SL. There is a loud droning noise - the kind that comes with harmonic resonance - when driving between 50-60 mph, but only when I have the hardtop on. It has nothing to do with RPMs, whether or not the engine is warmed up, etc. The hardtop is solid and well-sealed and pushing up on it has no effect on the noise. Does anyone have an idea what could be causing it and how to fix it?
tgbarton is offline
post #2 of 10 (permalink) Old 10-24-2011, 07:42 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 298 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
How is your rear wheel bearing doing?
You need to do few steps to find out where the sound is coming from...
-Find an empty road, and drive down at that critical speed.
-shift to N and see if the sound changes
-increase/decrease speed, how does the sound change?
-wobble the steering wheel, does the sound go away/ get louder?
-turn at high speed left, then right, does the sound get worse/better
- jack the rear end, (at a shop maybe), turn off ASR, then shift to D, let the wheels turn, can you hear loud noise at one wheel near the axle?
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #3 of 10 (permalink) Old 10-24-2011, 08:34 AM
silarrow's Avatar
Date registered: Oct 2009
Vehicle: 2000 :W220 -2002: W203 - 1986 W201: 16v Nam,16v Euro- 2002:SL500 Silver Arrow.2002:Avalanche-
Quoted: 32 Post(s)
I do think you may have interior air balance unstable, our R129 does not have body vent (Picture : kind like 190E's roof pillar side vents) .I can bet you won't have this problem with Canvas top but hard top at high speed. Try turn on the air circulation button and see any different ?
The German mind has a talent for making no mistakes but the very greatest
silarrow is offline
post #4 of 10 (permalink) Old 10-24-2011, 08:40 AM
bayhas's Avatar
Quoted: 298 Post(s)
never heard or noticed this issue with R129...
Garage:
Former Mercs:
bayhas is offline
post #5 of 10 (permalink) Old 10-24-2011, 11:21 AM
Date registered: Jan 2010
Vehicle: 1997 SL500, 1948 Rover 75 P3, 1984 Citroen 2CV, 1953 BSA Bantam D1, 1966 Velosolex Moped
Quoted: 21 Post(s)
Two thoughts in different directions a)Does opening the windows an inch or so, have any effect? b) Have you checked your rear tyres for unusual wear? My B*W has a habit of making the rear tyre tread sort of saw -tooth on the inside edge, and they just don't run smooth, even though there's visibly plenty of tread. Run your hands around tyre in both directions, and feel for a difference.
Hope you find the problem. Regards Steve
Steve6 is offline
post #6 of 10 (permalink) Old 10-24-2011, 12:31 PM
bayhas's Avatar
Quoted: 298 Post(s)
Steve,
you see this is called tire cupping, common irregular wear, caused by worn/damaged suspension arms or worn rubber bushings, causeing the wheel to wobble slightly...
Your solution steve is about 400 dollars in parts and MANY hours of labor, to replace all 8 links and the lower control arms, you can do it for less if you can identify the offending part, but since the newest R129 is now 10 years old, you might as well replace all arms while you re there...
The issue here, cupping (and suspension damage that will cause it in the first place), will cause physical vibration, way before the noise is audible, particularly in the morning when the tires are cold and hard... very obvious and annoying...
I dont think the original poster is reporting any shimmy vibration... are you?
Garage:
Former Mercs:
bayhas is offline
post #7 of 10 (permalink) Old 10-24-2011, 12:34 PM
bayhas's Avatar
Quoted: 298 Post(s)
HOW TO READ TIRE WEAR
Garage:
Former Mercs:
bayhas is offline
post #8 of 10 (permalink) Old 10-24-2011, 06:45 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 172 Post(s)
Good idea.
We may not have them in that location....
The vents/slots are located one by the battery, and the other on the opposite side.
But I don't think that is his problem.
Regards,
aam.
aam is offline
post #9 of 10 (permalink) Old 10-25-2011, 12:13 AM
Quoted: 21 Post(s)
Originally Posted by bayhas View Post
Steve,
Hi bayhas,
Thanks for the information, it certainly sounds like my problem although in this particular case I was referring to my daily driver 530 Beema which at 220,000 miles probably doesn't have an intact rubber bush anywhere . so you are probably quite correct. No shimmy but I think the cupped tyres are on the back. The R129 is fine (for the moment )
Regards
Steve
Steve6 is offline
post #10 of 10 (permalink) Old 10-25-2011, 05:30 AM Thread Starter
Thanks to everyone for the suggestions, but so far no go.
Cracking the windows and/or playing with the air circulation didn't have an effect. I also tried putting it in neutral to see if that stopped the sound, but it didn't, nor does weaving back and forth change the the tone/volume at all. There's no shimmying or unusual tire wear and the alignment on all four tires checks out fine. When changing speed, the sound only starts up at about 50mph, peaks at around 53mph and tapers off in volume by 57mph.
I haven't jacked up the rear end and run it in D yet. I don't have a button for ASR; how would I turn that off (if I even have it as a feature in the 300SL)? I can get the rear wheel bearing checked, but I'd think that would cause a noise at all speeds, wouldn't it?
It certainly helps to know that this is not a problem endemic to the R129, at least!
tgbarton is offline
    solved a droning engine noise rudidelange W203 C-Class 0 05-31-2011 10:19 AM
    S430 rear-end droning noise jade W220 S-Class 7 05-23-2011 09:02 PM
    Droning or low humming noise from rear of 1997 SL 500 bobbychu R129 SL-Class 17 05-08-2009 06:53 PM
    Loud Noise!!! momomo W220 S-Class 4 01-24-2008 02:56 PM
    Loud Noise!! Tatnhu W163 M-Class 12 02-01-2005 07:07 AM
