Symptoms: My car was never filling to full, more like a little less than 7/8. After driving about 30 miles the gauge would have dropped to around 3/4 and after ~120 miles the gauge was at 1/2 then would fall at a more gradual (possibly normal) rate.
Possible Cause: After reading multiple posts on Benzworld, it appeared to me that I had an issue with my Fuel Sending Unit (aka Fuel Sender, Tank Sender, etc.) I decided to remove mine and try cleaning it with electrical cleaner, as another poster said this worked for them.
I could not find any clear write-ups on it for our cars specifically, so I decided to take pictures along each step of the process.
1. These are the tools/supplies that *I* used for the removal of the FSU. Left to right: U-shaped piece of metal purchased from Lowe's from an house-antenna hanging kit; anything to provide leverage to turn the previous piece (I used a broken paint-stirrer Lowe's gave me to measure the distance between the two holes on the FSU); (recommended but not required) a set of hooks to pry the FSU out once it is loose; electrical contact cleaner
Attachment 385058
2. I was not about to go out and purchase a special tool that I will only use once or maybe twice, so taking inspiration from another thread, I decided to head to the hardware store, and picked up this packet. It was the only piece that had the correct distance between the two grey holes (you will see photos of later) and that was thin enough to fit into the wholes. It cost $5.31 with tax.
Attachment 385059
3. To begin, start the lowering process of the soft-top, but stop the motion once the lid for the top compartment opens (I let go of the button just after I heard the "pop" from the top of the windshield.)
Attachment 385060
4. It is much easier to move around with the seats all the way forward, and tilted forward as well. You will have to crawl underneath the top and get into the cubby behind the seats, so be limber
Sorry, I can't rotate the photo to be right-side up.
Attachment 385061
Continued in next post....
