DIY: R&R Fuel Tank Sending Unit (p/n 1295421117) with Photos - Page 4 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-11-2012, 07:01 PM   #31 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Mine was reading like two gallons less.
Then last week, I filled it to the top.
You got it works, nothing is wrong.
I never had to fill it up all the way, if the pump clicks to me, that it is enough.
Now I know better.
Not that I really care. Lol.
Regards,
aam.
aam is offline   Reply With Quote
Old 09-06-2012, 10:50 PM   #32 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Sport
Originally Posted by Griffin48 View Post
Suggestion: Right angle needle nose pliers could be used if necessary in place of the inverted "u" bolt to remove the tank unit.
I found the following Crescent Double-X Bent Long Nose Pliers - Tools - Hand Tools - Pliers & Sets at Sears for $19.95 and they worked great.
lynns is offline   Reply With Quote
Old 09-06-2012, 11:10 PM   #33 (permalink)
lynns's Avatar
My new, five month old, sending unit has been reading 7/8 th's of a tank when the tank is full so I pulled the sending unit and sprayed the electrical contacts with CRC- MAF electrical contact cleaner, let it dry, and reinstalled the unit and it now reads completely full.
Let's see how long this lasts.
Old 09-09-2012, 09:50 AM   #34 (permalink)
Date registered: Jul 2012
Vehicle: 2000 Mercedes-Benz R129 SL500 AMG SL2
Hmm, I've had some speculations regarding the function of my fuel meter and refueling. It appears as if some gas pumps can't manage to fill the tank to full, regardless if you top off. Some do fill pretty well in my case, I don't know why... I blame the gas stations! To me it depends on the pump more or less!
While we're on it, how far do you dare to drive in the yellow section? =) Everytime I decide to fill up, it only fuels up to around 67-68 liters. According to the manual, there should be 12-13 liters left! Maybe my fuel tank sending unit needs cleaning after all!
Regards,
Robin
anaesthesia is offline   Reply With Quote
Old 09-12-2012, 11:30 PM   #35 (permalink)
lynns's Avatar
Pin Wrench, 5mm pin, p/n 210 589 01 07 00
Mercedes fuel tank level sensor sender tool @ $29.99 w/ S&H | eBay
Old 09-13-2012, 08:27 AM   #36 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
My experience is : if I drive for a while and pull into gas station to fill it up, it will 'click' off early and the fuel gauge will not show full. But if I go to lunch first and then fill it up, gauge will show full. So may have to do with pressure in the tank ?
Anyway, long as I don't run out of gas it doesn't really bother me. When the empty light comes on, I can go another 40 miles with what's left.
RKH is offline   Reply With Quote
Old 09-13-2012, 09:03 AM   #37 (permalink)
lynns's Avatar
With the car it's an anal thing for me. But, if I had a bad fuel gauge while flying it could be more than a real problem.
Old 02-17-2013, 04:37 PM   #38 (permalink)
sd_cowboy's Avatar
Date registered: Dec 2007
Vehicle: 1997 SL320, 2011 Panamera 4
Thank you for a quality description of the task. It was very well put together.
Regards,
Griffin
I want to thank you too for this great thread! I just finished removing & cleaning my tank sensor as it wouldn't get much past 3/4 even when I knew the tank was full. The carpet in my storage boot was very well glued down so I ended up cutting a hole in it & will put in a patch once I know this sender is fixed.
I used a 2" wide "U bolt tool" as described and finally used the bench grinder my wife bought me years ago to grind the ends down to fit the socket holes. The sender turned easily & out it came for cleaning.
BTW, Autohaus lists a fuel tank sender seal part no. 1079971345 which is too small and does NOT fit so anybody else doing this R&R should save their $0.99.
mark
DIY: R&R Fuel Tank Sending Unit (p/n 1295421117) with Photos-sck_5980.jpg   DIY: R&R Fuel Tank Sending Unit (p/n 1295421117) with Photos-sck_5981.jpg   DIY: R&R Fuel Tank Sending Unit (p/n 1295421117) with Photos-sck_5983.jpg
sd_cowboy is offline   Reply With Quote
Old 02-25-2013, 06:07 PM   #39 (permalink)
board57796's Avatar
Date registered: Nov 2008
Vehicle: 2002 SL500 Silver on Black
Glad it helped! Easy job, huh?
board57796 is offline   Reply With Quote
Old 02-25-2013, 09:02 PM   #40 (permalink)
sd_cowboy's Avatar
Very easy job
Yes it was a very easy job thanks to your thread. Unfortunately, it didn't fix the sender so it looks like a new one for me.
Bookmarks
Fuel Tank Leaks & Fuel Sending Unit Failures tabkurt W211 E-Class 3 04-18-2013 11:31 PM
Hex Size on Fuel Tank Sending Unit? NorCalSL R/C107 SL/SLC Class 5 02-10-2010 05:56 PM
Fuel tank sending unit ejmatushek W208 CLK Class 8 11-14-2007 05:58 AM
Needs For DIY Fuel Tank Sending Unit zainal9977 W210 E-Class 2 07-11-2006 04:43 AM
Fuel Tank Sending Unit Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 5 11-08-2004 06:20 PM
