Power steering fluid substituted with ATF? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-24-2010, 08:32 PM Thread Starter
Date registered: Dec 2008
Vehicle: 1995 R129
Have anyone heard of using transmission fluid in lieu of power steering fluid? A mechanic told me that transmission fluid can be used as power steering fuid?
Keepontrucking is offline
post #2 of 9 (permalink) Old 12-24-2010, 09:12 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 457 Post(s)
Toyota uses ATF as PS fluid but that was specified by Toyota. They use ATF in their manual transmission too.
But I don't think you want to do that for your MB.
RKH is offline
post #3 of 9 (permalink) Old 12-25-2010, 09:41 AM
RoadKing's Avatar
Date registered: Sep 2007
Vehicle: 2007 CLS 550, 1998 Harley Road King, 2011 F-150 EcoBoost, '65 Shelby Cobra
Yes, you can and it doesn't really matter, however, why not use the right stuff. It's not like you are using it as fuel at $3.50 a gallon.
Mike
I don't downshift often, but when I do, it is next to a Prius so I can show them how I am hurting the environment! -
'07 CLS 550
RoadKing is offline
post #4 of 9 (permalink) Old 12-25-2010, 10:23 AM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 171 Post(s)
It may make a difference in cold countries..
(I am not even sure of that.)
I have been using it
for years.
Why pay more?
Regards,
aam.
aam is offline
post #5 of 9 (permalink) Old 12-25-2010, 08:53 PM
4benzes's Avatar
Vehicle: 2111 GLK 2000,2003 ML 350,2006 R350,1996 300D, 2001 C
Send a message via AIM to 4benzes
Aam
Exactly how much are you using that price would matter? Do you have a leak?
4benzes is offline
post #6 of 9 (permalink) Old 12-25-2010, 08:58 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 278 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
Yes, you can use ATF, but to achieve the best corrosion protection, use specific MB fluid, it is very inexpensive...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #7 of 9 (permalink) Old 12-25-2010, 10:04 PM Thread Starter
Vehicle: 1995 R129
Thanks everyone,
I had a leak of Power steering fluid and fixed it. (tube between resorvoir and pump). I had used the transmission fluid as PSF in past and wanted to continue using it because I did not notice any problems with it in the past. Just wanted to know if anyone had any suggestion as to whether or not I was doing something that could cause problem down the road.
post #8 of 9 (permalink) Old 12-26-2010, 12:32 PM
aam
aam's Avatar
Quoted: 171 Post(s)
Originally Posted by 4benzes View Post
Aam
Yes I did....
I have posted it, in the past.
The return lines are pron to leaks, cheap repair hard to locate, and little space to work.
There are two small hoses that you buy by the meter, I think it was 10mm.
you only need about 18" but at $6 ???
Replace the filter while you there.
The one is almost strait so it lasts longer, the other is like a pig tail, you need that shape because of engine movement.
With time it drys and leaks at the clamps.
Especially when the engine mounts are old/loose.
But what is easy work on our cars? Haha.
If you have to do this work, pay attention to the clamp position, so you can tighten them from the top.
You will also need a very long Philips screwdriver, or & 1.4 ratchet with long extensions etc.
Yes you will have oil all over the place, so be prepared.
Send the wife to visit her mother, (long visit...)
It will be much, much, easier for you. Haha.
Regards,
aam.
PS.
About using tranny fluid, in power steering.
I am talking for the ball recirculation type power steering.
If there are no leaks, the $15 MB is not important so do get it.
But lets say that you are away/leaks and you need it, don't run it dry.
Don't forget to periodically tighten the three bolts on the gear box, or it will leak.
aam is offline
post #9 of 9 (permalink) Old 12-27-2010, 10:32 AM
Date registered: Jun 2009
Vehicle: 1994 SL500
I quit substituting fluids about 15 years ago when the main ram seal failed suddenly on my floor jack and the car fell. fortunately no one was underneath when it happened. When I took the seal to a repair place to get a new one the person looked at it and said you can not use power steering fluid in floor jacks it deteriorates the seals. There is a GOOD reason that they use specific fluids for specific systems.
grumpy old man is offline
    Can I use synthetic ATF in my power steering? hheynow W123 E,CE,D,CD,TD,TE Class 7 09-02-2009 07:14 AM
    Can ATF be used as power steering fluid? iluvjesus W210 E-Class 30 06-02-2009 09:24 PM
    ATF for power steering FLUID ? WeVonBraun W123 E,CE,D,CD,TD,TE Class 7 08-08-2007 03:06 PM
    ATF & Power Steering Fluid! sss11 W126 S,SE,SEC,SEL,SD,SDL Class 4 04-13-2004 12:49 AM
    Anyone know if power steering uses ATF fluid??? Guest (MBNZ) W210 E-Class 2 06-05-2001 04:00 AM
