edcarls I Tryed Your Way And Nothing Worked Here Is My Problem
My Alarm 1/2 Works On My 96 R129 SL500 ??
This Is My Story
I Got This 96 SL 500 About 2 Years Ago, When O First Got It , I Wanted To Clean It Up Real Good, So I Washed The Eng Compartment Eng And All, Came Out Real Clean.
Then I Put On A New Hood Pad, And That Was It, Every Thing Worked Real Good Alarm And All, Even The Fog Lights Came On When I Got Out Of The Car At Night Like There Made To Do.
Well About 3 Days Later The Alarm Went Off, So I Turned It Off With The Key In The Door, Ever Since Then I Get Noting Out Of The Alarm Any More ,, No Sound Or Fog Lights Or Blinking Front And Rear Lights ,, Nothing The Red Light On The Dash Dot Blink Either Only The One In The Radio The Alarm One Don't Light Up Or Blink.
I Did Try To Open The Drivers Door With The Window Down Reached In Opened The Door NO ALARM SOUND, So At That Point I Tried To Start The Car , It Did to Start, So Then I Used The Key Button To Unlock The Car With The Two Lights Under The Rear View Mirror RED & GREEN Then The Car Started Ok.
I Checked All The Fuses Under The Hood & In The Trunk ALL OK
So I Changed The N 54 Alarm Module In The Trunk , And No Results That Was Any Different, Same Thing.
I Have No Place To Look Except The Relays , My Question Is What Relay Should I Be Looking At, Or What Should I Do To Fix This Problem ?
Thank You All For Reading My Problem, And Thank You For Any Help That I Might Get From You Nice Folks Reading This Please Help Me Out
Thank You
Harley03joe
Plus
night security illumination, Don't Work
Are All The 96 SL500 Head Light Switches The Same Or Do Some Have The night security illumination System In Them ?
I'm Asking Because I Replaced Mine And 1 Year Or So Ago And Just Saw That My night security illumination Don't Work Any More, Or Is There A Relay Someplace ?
Any Help With This
Thank You
Harley03joe
