<<< Wheel bearing play - alternative to using a dial gauge? - Mercedes-Benz Forum
post #1 of 29 (permalink) Old 07-12-2010, 08:13 PM Thread Starter
dbischoff's Avatar
Date registered: Nov 2009
Vehicle: 2001 SL500, 2012 Corvette Z06, 2013 Lexus RX350, 2012 Cadillac CTS Coupe, 2015 Ram Sport
Quoted: 47 Post(s)
I obsess about clean wheels, and the brake dust on my 01 SL500 drives me nuts, as does the squeaking brakes. So, I just purchased Akebono pads and new rotors front and back, with plans to replace them myself.
As I read more about it I realized that the hub has to be pulled to remove the rotors, because they are bolted from behind. So, I might as well replace the wheel bearings while I am at it. I think I might have a slight vibration in one anyway.
I read a thread on another forum where someone was scolded for using the old-time method of tightening the hub nut and then backing it off a little bit to allow enough play. That's how I would have done it. Now I'm worried.
The prescribed method is to use a dial guage - this just keeps getting more expensive.
Is it possible to use a simple feeler gauge to measure the play?
What about the rear brake rotors? Do I need to pull the hubs/axles? I sure hope not.
dbischoff is offline
post #2 of 29 (permalink) Old 07-13-2010, 09:15 AM
chriswufgator's Avatar
Date registered: Oct 2007
Vehicle: MB SL600, MB 380SE, Suzuki Grand Vitara, 38' Chris-Craft, Volvo V70XC, and my own two feet...
Quoted: 2 Post(s)
Send a message via AIM to chriswufgator
You can repack those wheel bearings.
"Veni, Vidi, volo in domum redire." (I came, I saw, I want to go home.)
chriswufgator is offline
post #3 of 29 (permalink) Old 07-13-2010, 09:36 AM
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 223 Post(s)
Your can R&R the brake rotors without pulling the hub/axles. The rotors are attached to hub by Allen or Philips head screw.
edcarls is offline
post #4 of 29 (permalink) Old 07-13-2010, 09:50 AM Thread Starter
dbischoff's Avatar
Quoted: 47 Post(s)
Yes, I can, but I will still have to set the correct play when I reassemble.
post #5 of 29 (permalink) Old 07-13-2010, 11:26 AM
12pack's Avatar
Vehicle: 1997 SL600
I'm interested in this too. When I look at the hub and bearing it just looks like a hub and bearing. It doesn't use a castelated nut and cotter pin in favor of its fancy pinch thing, but the technique should still apply.
BTW here is a great tutorial (the secret in the sauce is backing off and tightening down multiple times IMO) :
How to Clean Spindle & Rotor on Cars: How to Repack Grease & Adjust Wheel Bearing in Cars | eHow.com
12pack is offline
post #6 of 29 (permalink) Old 07-13-2010, 12:22 PM
Quoted: 223 Post(s)
There is really no secret on setting the bearing load without using a gauge. I can't explain it in words because I do it by "feel". Based on experience one would know the feel of a correct (or almost correct) wheel bearing load adjustment.
Please note that if it was set tight than acceptable spec the bearing would hum, heat up and seize, too loose the wheel would vibrate.
I learned how to do it because we (my father and brother) used to make a bet on who could set it closest to spec with out using a gauge. We each set it manually and check it with a gauge, the closest win. We also do it with torque specs with out using torque wrench. Little did I know that these games would be of value to me later.
edcarls is offline
post #7 of 29 (permalink) Old 07-13-2010, 04:38 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 391 Post(s)
it was a few years ago when I started a similar topic.
I took my 1993 SL500 to have the wheels aligned, but the mechanic said there was play in the front wheel bearings.
Of course they gave me a very high estimate to replace the bearings.
I took the car home and just repacked the grease and tightened the bearings, it's still running fine (even at 240KPH).
I can still remember Albert (aam) saying, just tighten them enough so they run on the grease
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is online now
post #8 of 29 (permalink) Old 07-13-2010, 06:26 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
I picked one up with the magnetic mount for about $30 at harbor freight. Fine for casual use.
G-AMG did a pictorial DIY on the proper adjustment method based on the WIS (on a 210, but it's the same setup) in case you're interested.
http://www.benzworld.org/forums/w210...free-play.html
Check Codes is offline
post #9 of 29 (permalink) Old 07-13-2010, 07:12 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 171 Post(s)
Haha.
I have never used a dial gauge for tightening the bearings.
Maybe it is because I am lazy or primitive? Haha.
Guys do not exaggerate.
Tighten the new bearings with a pliers or something to seat them in, while turning the
hub by hand.
Then back the nut out.
Then only then finger tighten the nut, and lock it down.
That's it........ Sugar coating is extra.
Been doing it for many decades, my cars do not pull to any side, with this method.
Now who was saying that it should always run on a coat of grease, not metal to metal?
Oh, I forgot maybe it was I? Haha.
You have a hell of a good memory James, that was a long time a go.
By the way in order to replace the rotors you must remove the hub and bearings,
the 10mm Allen screws are in the back of the hub.
Put the hub in the wheel with a few screws to hold it, hold the tire so you can loosen the 10mm screws. (They are very tight.)
I have broken a few 3,8" ratchets doing it, didn't have my 1.2" with me.
Get a 1.2" and a long pipe after it.
(You will need that pipe.)
Now if you have a good supply of air and an air air gun.......
Regards,
aam.
aam is offline
post #10 of 29 (permalink) Old 07-13-2010, 09:12 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 292 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
adjusting the wheel bearing play is discussed in details in WIS. the same document should be in AllData
what you do is you take the dust cap off, undo the locking allen bolt for a few turns, then adjust the end play by turning the main nut.
the article lists max play, that if you reach, you need to replace the bearing.
None the less, doing the brakes only will not get you to the bearings, because you do not have to remove the hub. did you mistake the Merc hubs for Honda?
BTW Honda Accord had the wierdest design for hub I ve ever seen... so time consuming to service...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
    photo diy- wheel bearing "free-play" measurement G-AMG W210 E-Class 27 04-12-2016 09:09 AM
    How do you use dial indicator/gauge for front wheel bearings? torkq W123 E,CE,D,CD,TD,TE Class 13 05-10-2011 10:42 PM
    Instrument dial gauge fitment issues? 85300CD W123 E,CE,D,CD,TD,TE Class 0 01-15-2010 02:37 AM
    1993 300te rear wheel bearing play. dirtyhands W124 E,CE,D,TD Class 10 11-06-2008 06:42 PM
    IMPORTANT: Wheel Bearing Play ? Serintek W126 S,SE,SEC,SEL,SD,SDL Class 7 11-19-2007 06:47 PM
