Removing AC side vent - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 05-24-2010, 08:55 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 99 SL 500
Hello all,
My AC vent on the driver's side no longer moves when I try to direct it side to side. I want to remove it to see if it can be fixed. Does anyone know how to remove it without breaking it? (picture attached)
Thanks.
steelbridge1 is offline   Reply With Quote
Old 05-24-2010, 10:33 AM   #2 (permalink)
Date registered: Jan 2006
Vehicle: 1991 500SL
Yep...I just changed my right side vent.
Start up close to the windshield above the tweeter cover and pop off the plastic strip. That will allow you to then lift up the tweeter cover, gently, and that will expose the two screws holding the vent onto the dash. The vent just pushed into the plastic air duct for the AC.
What I found is that there is a little wire that "sits" into the vertical plastic panes inside the vent housing. When you move them side to side the wire keep the panes in alignment and moves them in unison.
Good luck.
David
davidby is offline   Reply With Quote
Old 05-24-2010, 11:32 AM   #3 (permalink)
Vehicle: 99 SL 500
Thank you, David.
Bookmarks
Central vent cold air, side vent warm air, help please Benz235 W202 C-Class 6 07-24-2009 11:38 PM
Mysterious Side vent & Center vent echaocn W210 E-Class 1 04-20-2009 10:04 PM
230 side vent Yes or No roncallo R/C107 SL/SLC Class 18 07-13-2008 10:54 PM
Driver side AC vent removal Airjunky W163 M-Class 0 12-29-2004 12:55 PM
Side vent air volume shmelvin W140 S-Class 0 05-03-2004 03:15 PM
