Any tricks to replacing 91 SL500 antenna? - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 03-19-2010, 12:41 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1991 Mercedes 500 SL
Quoted: 2 Post(s)
I'm a new Benz guy.
My antenna was recently shortened by a car wash. Prior to going in, it stopped working (retracting). I took a chance and lost. Afterwards, I noticed why it wasn't retracting and remedied that.
I've purchased the replacement (at a whopping $140...even the Benz parts guy asked if I still wanted it after mentioning the price) and am wondering what the sequence is to replace it. There is a toothed strip of plastic located inside the antenna attached to the tip and extending about 18" out of the base. I'm wondering how it will know where the start and stop points are. I'm not ready to do this wrong and end up at that parts counter again.
Any help out there?
Kitchengod is offline
post #2 of 27 (permalink) Old 03-19-2010, 04:29 PM
ulflei's Avatar
Date registered: Aug 2005
Vehicle: 85 300SL Euro,97 SL320,95 S420,07 S550
Quoted: 2 Post(s)
If he went to the dealer ship he only got a new mast from Hirschman (for $140.00 you don't get the whole unit,that's why the clerk asked).
So turn your radio on, take the old mast or whatever is left from it out, and feed the new one in by shutting your radio off .Takes only a minute.
ulflei is offline
post #3 of 27 (permalink) Old 03-19-2010, 04:58 PM
bearone2's Avatar
Date registered: Apr 2008
Vehicle: 2000 SL500 SL2 Triple Black
Quoted: 5 Post(s)
you do need to loosen the nut 1st or it won't spool out.
2000 SL500 SL2
"Good judgment comes from experience which comes from bad judgment."
bearone2 is offline
post #4 of 27 (permalink) Old 03-19-2010, 05:37 PM Thread Starter
Quoted: 2 Post(s)
Which nut are you referring to? Is it the chrome one that holds the antenna down?
post #5 of 27 (permalink) Old 03-20-2010, 06:43 AM
ulflei's Avatar
Quoted: 2 Post(s)
yes thats the one
ulflei is offline
post #6 of 27 (permalink) Old 03-20-2010, 10:57 AM
007Silvertoe's Avatar
Date registered: Dec 2009
Vehicle: 1995 Mercedes SL320 Roadster
Send a message via Skype™ to 007Silvertoe
I actually had to replace my antenna mast due to the same problem, except the car was literally bent mine in half after realizing the power button on my new head unit wouldn't retract the antenna.
Simply turn on your radio so your antenna is extended fully, loosen the chrome colored nut at the base of the antenna mast and pull the antenna out (it may require some force, but you won't harm anything), also take note at the direction of the grooved teeth when you pull it out, mine faced the back of the car. Once that is said and done take out your new antenna and put the white-grooved plastic strip in your antenna slot in the same direction it was originally (if you don't remember you can still figure it out, it will take awhile to get the right direction..) push the grooved wire down as far as you can with a little extra push as the end when it stops moving, the wire should be able to support the antenna from this point without falling out...for the next part i recommend a towel or shirt around the base of the antenna to prevent paint damage to your car when the antenna retracts...then simply turn off your radio, and it should pull the antenna in! Your going to want to try and guide it into the slot once you turn your radio off, then simply fasten the chrome screw and your set
007Silvertoe is offline
post #7 of 27 (permalink) Old 03-20-2010, 02:55 PM
rriggi129's Avatar
Date registered: Oct 2009
Vehicle: 2007 911 GT3 RS, 1990 420SEL, 2007 S550, 1994 SL500 6.0, 2011 Aston Martin DBS
While we are speaking antenna's here, does anyone have the p/n for the Plastic seal around the antenna on the outside of the car? Mines aged and cracked..
1994 SL500 6.0 AMG - too many modifications to list
rriggi129 is offline
post #8 of 27 (permalink) Old 03-20-2010, 03:34 PM
Date registered: Jun 2007
Vehicle: 1995 SL 500 2017 AMG GLC 43
Quoted: 10 Post(s)
Lee Wireless is offline
post #9 of 27 (permalink) Old 03-24-2010, 10:53 AM
I bought the second seal in the link you posted above when I ordered my antenna from there as well, fits perfectly.
post #10 of 27 (permalink) Old 01-09-2011, 09:31 AM
iresfrank's Avatar
Date registered: Mar 2010
Vehicle: "NEW OWNER" of a 1991 SL 500 weekend toy. Hope I don't go broke maintaining it!
Originally Posted by Lee Wireless View Post
HI ALL ! ANYONE know how I can get the 1990-1991 seal for my older SL 500??
The one listed here is 1993 and newer. I've been searching for the 1990-1992 but don't even know if it is black or chrome as my car never had it to begin with so I don't even know what I'm looking for.
Any help with my p/n is enormously appreciated!!
Confident enough to be dangerous
iresfrank is offline
    Replacing factory antenna BenzUberAlles W163 M-Class 3 10-13-2009 11:40 AM
    Replacing master cylinder... any tricks? Cyberbach W123 E,CE,D,CD,TD,TE Class 6 03-11-2009 10:27 AM
    replacing antenna seal cheverney R/C107 SL/SLC Class 6 05-28-2008 11:11 AM
    replacing antenna Nathanb30 W124 E,CE,D,TD Class 6 04-12-2005 09:01 AM
    replacing antenna grommet 84300DTurbo W123 E,CE,D,CD,TD,TE Class 3 01-09-2005 06:34 PM
