Check trans fluid while running? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 01-16-2010, 12:07 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1995 SL500
Do you check transmission fluid level with car running or not? Running is what I have done on other cars. I am having the sluggish reverse when hot. When I got the car one month ago a major selling point was rebuilt trans for you guessed it, sluggish reverse.
Want to start with the fluid and I have already contacted the dealer and guy who rebuilt trans to get them to stand behind whatever this turns out to be.
As a side, I got the car warm, drove a bit too warm up trasnmission and while running fluid is not even at bottom cold mark. It is nice and new fluid at least.
Found it, check well running, I am definitly low then. When cold car hits reverse fine, usual symptom from thread I have read. I will try fluid first and go from there.
500SL4Me is offline
post #2 of 12 (permalink) Old 01-16-2010, 01:03 PM
bearone2's Avatar
Date registered: Apr 2008
Vehicle: 2000 SL500 SL2 Triple Black
Quoted: 5 Post(s)
do it when it's hot, don't overfill it.
2000 SL500 SL2
"Good judgment comes from experience which comes from bad judgment."
bearone2 is offline
post #3 of 12 (permalink) Old 01-16-2010, 01:44 PM Thread Starter
Vehicle: 1995 SL500
I just did, drove around for a long while, it took a quart and I am still not sure it is full. I am not hitting between the final two marks at the 180F marks. I find it hard to believe that the mechannics who R&R'd the transmission could have underfilled this much and I am indeed not wanting to overfill.
It seems to have helped a bit but hard to say. Incidently I can go up steep incline in reverse no problem but does take a bit of rev before it really engages.
What is the capacity of this bad boy?
If the rebuilder and dealer does not come through (as is no warranty mentality) I will live with it I guess. We shall see. I will check it tomorrow when cold, and have some long driving to do and then check when hot again to be sure. Then I will drive the car off a pier into Lake Michigan ;-)
500SL4Me is offline
post #4 of 12 (permalink) Old 01-16-2010, 02:48 PM
bearone2's Avatar
Quoted: 5 Post(s)
there are two lines, one cold, one hot, as the fluid expands.
i don't follow the relationship of dealer and guy who did the tranny and the selling point, was it sold "as is" or an implied or written warranty for tranny work?
2000 SL500 SL2
bearone2 is offline
post #5 of 12 (permalink) Old 01-16-2010, 02:56 PM Thread Starter
Vehicle: 1995 SL500
I got the car one month ago and the dealer I bought it from had the tranny rebuilt due to reverse issue. I have the $1,500 invoice, it was actually a ncie selling point for me. The trans rebuilder says no warranty but the dealer is trying to get them in line. We shall see. I spoke directly to the trans rebuilder and he said bring it by it may just need some adjustment. He's not exactly close and I will try to get their next weekend. Thankfully this is not a daily driver.
Yes, I am aware of the cold and hot range on the dipstick and will check again tomorrow. I checked today after I put the quart in (I actually added little by little) with driving in between.
500SL4Me is offline
post #6 of 12 (permalink) Old 01-16-2010, 03:02 PM
bearone2's Avatar
Quoted: 5 Post(s)
you don't need to drive it in between adding fluid. make sure it's a flat surface and keep keep adding a little until it's where it should be.
if the the rebuilder doesn't stand behind the work the dealer should. take in to mbusa if you have to.
2000 SL500 SL2
bearone2 is offline
post #7 of 12 (permalink) Old 01-16-2010, 04:10 PM Thread Starter
Vehicle: 1995 SL500
Not an MB dealer unfortunately, just your basic ole' used car joint. I am gonna go pour a drink and think positively for the weekend. Nothing else I can do right now.
500SL4Me is offline
post #8 of 12 (permalink) Old 01-16-2010, 07:24 PM
bearone2's Avatar
Quoted: 5 Post(s)
that's why it's recommended to get a ppi before making a purchase, to see what good/bad you're dealing with.
2000 SL500 SL2
bearone2 is offline
post #9 of 12 (permalink) Old 01-16-2010, 09:21 PM
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, CL55, E350, E320
Quoted: 4 Post(s)
I check mine when the engine is running. Once at 25 degree and once at 80 degree (C). I bought the laser gun and pointed at the pan to measure the temperature. This is for the 722.6 tranny though.
lnguyenh is offline
post #10 of 12 (permalink) Old 01-17-2010, 04:41 AM Thread Starter
Vehicle: 1995 SL500
Can I borrow your time machine In hindsight I could have found a better car for the money, but such is life. She is mine now and I will get her sorted if it kills me and my bank account.
Best case, they come through for me, not so best case I drive it for years with a slow reverse, worst case, someday I order up a rebuilt trans for $1,500 and have my indy put in one day.
500SL4Me is offline
    Trans fluid check chop-gsxr W202 C-Class 2 08-04-2009 05:54 PM
    How do I check the trans fluid??? AdamHarward Unimog 9 04-16-2009 07:32 PM
    Does low trans fluid cause check engine? bigwiki W124 E,CE,D,TD Class 2 08-12-2008 08:35 PM
    Check trans fluid while running? DucatiSteve R170 SLK-Class 9 08-02-2007 02:10 PM
    How check Trans Fluid? Newbee R170 SLK-Class 4 02-25-2005 09:06 PM
