1999 SL500 Engine Problems? - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 12-02-2009, 03:58 PM Thread Starter
Date registered: Sep 2009
Vehicle: 89' 560 SL 99' SL500 10' GL450
I have a 1999 SL500 that I bought from my father who bought the car brand new. The car has only 18,000 pampered miles on it. My father always had the oil changed every 6 months at the mercedes dealer. I took the car in to have a new soft top put on it because the old one had the windows yellowing. I received a call from the repair shop telling me that they noticed a noise coming from the engine. Originally he thought it was coming from the bottom of the engine, but they pulled the pan and there were no metal shavings and everything looked fine. Then he said they manually turned the pistons and noticed some slight resistance from one of the pistons so he thought it was a valve problem. Now he says that the timing belt has slipped and that is what is causing the noise, he also said he pulled all the plugs and plug #8 and #4 has burned oil on it. He said that Mercedes has a known problem with their aluminum engines and the sidewalls of the piston cylinders. Has anyone else out there had any similar problems or is this guy just trying to get me. I don't know him, but he was the only guy in the area that could replace the top. Please help because I don't know whether to trust him or not.
Greg 560 is offline
post #2 of 22 (permalink) Old 12-02-2009, 04:02 PM
bearone2's Avatar
Date registered: Apr 2008
Vehicle: 2000 SL500 SL2 Triple Black
Quoted: 5 Post(s)
just to confirm, you took it to the same dealer or a private shop?
i hope the top needed replacing instead of just yellow windows.
2000 SL500 SL2
"Good judgment comes from experience which comes from bad judgment."
bearone2 is offline
post #3 of 22 (permalink) Old 12-02-2009, 04:07 PM Thread Starter
I took it to a private shop because they were the only ones interested in replacing the top
Greg 560 is offline
post #4 of 22 (permalink) Old 12-02-2009, 04:22 PM
Date registered: Nov 2006
Vehicle: 2003 SL55
Quoted: 21 Post(s)
you do realise you could have cleaned those yellowed windows back to clear with a few bucks worth of product.......are you sure the shop didnt just clean it in half an hour and charge you a few grand for a new top....
theintelligent1 is offline
post #5 of 22 (permalink) Old 12-02-2009, 04:30 PM Thread Starter
Yes, they did replace it because it had some other problems than just the yellowing windows.
Greg 560 is offline
post #6 of 22 (permalink) Old 12-02-2009, 04:38 PM
chriswufgator's Avatar
Date registered: Oct 2007
Vehicle: MB SL600, MB 380SE, Suzuki Grand Vitara, 38' Chris-Craft, Volvo V70XC, and my own two feet...
Quoted: 2 Post(s)
Send a message via AIM to chriswufgator
Ummmm....
GTFO out of that shop ASAP. They're either complete idiots, or they're trying to scam you, or probably some combination of both. Your car doesn't even have a "timing belt", it has a chain and it's impossible that it could have jumped timing, as there's zero stretch with 18k miles on it. Go pick it up NOW. If it doesn't run have it towed somewhere else to get the work finished. Sounds like these guys are bad news.
Also, there's no way the top needed replacing with 18k on the clock. You could have just replaced the back portion. I personally don't like cleaning the windows, because that gets you into these ever-shortening cycles of having to clean them and clean them. Once you abrade the plastic surface, they seem to get cloudy faster and faster each time. But with that kind of mileage, I'd probably have given it a shot.
You're getting ripped a new one, man.
"Veni, Vidi, volo in domum redire." (I came, I saw, I want to go home.)
chriswufgator is offline
post #7 of 22 (permalink) Old 12-02-2009, 04:38 PM
Quoted: 2 Post(s)
What else was wrong with the top?
post #8 of 22 (permalink) Old 12-02-2009, 04:39 PM Thread Starter
sorry, my bad it does have a timing chain not belt, my typo.
Greg 560 is offline
post #9 of 22 (permalink) Old 12-02-2009, 04:42 PM
Quoted: 2 Post(s)
Yeah, but it's not just a "typo". Timing chains don't "slip", they usually won't jump timing even if they're way stretched and the tensioner and guides are worn out. About the only way you can lose a motor with a chain this way is if it breaks. But nothing's wrong with the chain, guide, or tensioners at 18k miles anyways, that's hogwash. I'm telling you, this mechanic is taking you for a ride. Go get the car, and you may as well go ahead and start fighting now over the no-doubt ridiculous bill coming down the pipeline, to save yourself time later.
post #10 of 22 (permalink) Old 12-02-2009, 04:42 PM Thread Starter
the top had some small snags in it and stains. The car came from arizona and I don't know if it was the heat or what, but the top was extremely dirty and I tried to clean it to no avail.
Greg 560 is offline
    1999 C230 Kompressor, engine fuel/shifting problems. MadManuel W202 C-Class 8 11-02-2011 04:20 PM
    1999 108CDI Engine problems Gav16 V-Class 2 08-28-2008 08:40 AM
    1999 sl500 speedmaster2 R129 SL-Class 1 02-12-2008 06:08 AM
    1999 mercedes SL500,check engine light on felderlostnspace General Mercedes-Benz 10 02-20-2007 06:30 PM
    Will 1999 sl500 Rims fit 1997 SL500 Black129 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 08-11-2003 11:09 AM
