» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 11-21-2009, 08:04 PM   #1 (permalink)
Date registered: Jan 2008
Vehicle: 2001 SL600; 2002 SL600
How do I get my car up on pin jacks?
Greetings,
I tried to search the forum first, but came up dry. Are there safe jacking points under our cars other than the standard four "pad" sites? I need to get my car up on pin jacks in my garage using my hydraulic floor jack. Using the floor jack under a pad to lift the car means I can't then put the pin jack under the pad. Are there areas under the car other than the pad sites that can support the weight of the car when using a floor jack?
Thanks, Joe D.
mrsaydz is offline   Reply With Quote
Old 11-21-2009, 09:06 PM   #2 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
Either use the emergency tire jack for lifting or find a rod or re-bar that fits into the hole where the emergency tire jack goes and used your floor jack on that. Make sure the rod will not slip off the jack (may be welding a disk on it?) Performance Products sells such a adapter for Porsches ($29) but I don't see any for MB.
RKH is offline   Reply With Quote
Old 11-22-2009, 05:55 AM   #3 (permalink)
phendriks's Avatar
Date registered: Oct 2008
Vehicle: 1991 300sl
Did you want to lift the entire car or just one corner?
phendriks is offline   Reply With Quote
Old 11-22-2009, 09:07 AM   #4 (permalink)
Thanks.
I need to have the entire car off the ground. I didn't think to use the emergency jack...duuuh! During the winter season, I'm going to have the wheels refinished & don't have a spare set to put on. Thanks, guys for the advice.
Old 11-22-2009, 06:00 PM   #5 (permalink)
JSBulmer's Avatar
Date registered: Dec 2008
Vehicle: 1988 300E - Diamond Blue, 1997 SL320 - Black Opal
Am glad this topic came up as I have wondered the same thing.
I had though of getting an I-beam and place it under the two jack pads and then from each side raise the car with floor jacks and then place the jack stands underneath. Just couldn't figure out whether it would be safe and secure.
Any thoughts?
jb
John Bulmer, P. Eng.
Medicine Hat, Alberta
1988 300E
1997 SL320
1994 GMC K2500
JSBulmer is offline   Reply With Quote
Old 11-22-2009, 06:09 PM   #6 (permalink)
phendriks's Avatar
Vehicle: 1991 300sl
you may want to consider this
Old 11-22-2009, 07:24 PM   #7 (permalink)
JSBulmer's Avatar
That looks cool.
Unfortunately it wouldn't work for my garage for long term as space along the sides of the car are at a bit of a premium. I've squished 3 cars in to a 2 car garage - I have the depth but not the width.
jb
Old 11-23-2009, 08:08 PM   #8 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
I usually lift the whole car on four hydraulic jacks.
I use the rubber jack places.
But in your case you can use only one or two, for the front I put the stands
at the cross member under the engine. (The heavy one only.)
At the rear I use a piece of two by four X10" long I put the jack a little at the front
so the stand will be at the right place.
Some people are using the differential, but I don't like to force the support and also may brake the dif. mount.
Remember that the rear is much lighter.
Regards.
aam.
aam is offline   Reply With Quote
HELP ! 38 PIN diagnostic plug pin numbering mrmuzic W124 E,CE,D,TD Class 4 09-04-2009 08:04 AM
Car Jacks up but tire stays on ground HandBanana W124 E,CE,D,TD Class 11 05-22-2009 12:18 PM
9-Pin or 10-Pin Fuel Pump Relay w/ Kickdown woulfe27 W201 190 Class 2 02-17-2009 09:55 AM
Headlight install question - 4 pin and 3 pin TO 5 pin and 2 pin eurodriver W202 C-Class 2 12-19-2008 02:55 PM
Car Pin Vesnica W203 C-Class 7 03-14-2006 02:42 PM
