Connecting bi-xenon HID to Fuse Box - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-29-2009, 06:39 PM Thread Starter
Date registered: Sep 2006
Vehicle: 1998 SL500, 1993 300SE, 1991 300SD, 1995 E320 Cabriolet
Question Connecting bi-xenon HID to Fuse Box
I received a 9004 bi-xenon kit from xenonlink. This requires a connection to the battery (which is in the trunk as we all know). I have read the HID posts and have read various others' suggestions of wiring this HID connection into the fusebox and splicing this to one of those wires for power.
I can see how to get the HID kit wire requiring power into the fusebox via empty grommets. Once I am there where should I splice this connection to connect safely to power? I am afraid of frying something and do not want to cause electrical problems.
Thanks,
rogerpart is offline
post #2 of 10 (permalink) Old 10-30-2009, 01:57 AM
Administrator
RedLiner's Avatar
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 396 Post(s)
Remember to disconnect the negative side of the battery before working inside the fuse-box.
If the HID kit comes with it's own fuse/es, splice into the fat red wire inside the fuse-box. If there are no fuses with the HID kit then it's best to find the headlamp fuse and connect to the fused side of the wiring.
EDIT: You will also probably want to remove the 'lamp out' warning light on the instrument cluster as this will illuminate when you switch on the headlamps.
If yours is a LHD car there's no need to remove the cluster, just drop the panel below (four screws) and twist out the warning light and remove the bulb.
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #3 of 10 (permalink) Old 11-02-2009, 08:21 AM
benzmanbandit's Avatar
Date registered: May 2009
Vehicle: 92 500SL- ALPriority Lazer- V1/YAV1- Ultimate Detction RADENSO Radar
Quoted: 2 Post(s)
Rogerpart check your private msgs
Check your message
benzmanbandit is offline
post #4 of 10 (permalink) Old 12-10-2009, 02:34 PM Thread Starter
Benzmanbandit was going to send some pics of his xenonlink bi-xenon install---but he has been absent from the forum lately so I am hoping Redliner or someone can provide me some direction to get started.
I have a 9004 bi-xenon kit from xenonlink which requires a connection to the battery (which is in the trunk as we all know). My kit has a fuse to prevent the bulb out warning light.----- I have read the HID posts and various others' suggestions of wiring this HID connection into the fusebox and splicing this to one of those wires for power.
[QUOTE=RedLiner;3791044]Remember to disconnect the negative side of the battery before working inside the fuse-box.
Redliner
----when I remove the fusebox cover, I do not see any obvious "fat red wire". Do I need to remove the fusebox by unscrewing the screws to access this wire?
If anyone has any pictures or DIY directions etc I would much appreciate this.
Thanks....can't wait to see better at night!
post #5 of 10 (permalink) Old 12-10-2009, 07:18 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 172 Post(s)
You may want to take it from the source.
In the module compartment.(Right engine side, next to the hinge.)
The battery cable comes from the battery direct to that location.
In there it splits to the fuse box, alternator, etc.
Start at the connector with a fuse and way you go.
Take as many amps as your heart desires.
Regards.
aam.
aam is offline
post #6 of 10 (permalink) Old 12-11-2009, 02:57 PM Thread Starter
Smile
Regards.
aam.
aam, (thanks for your suggestion)
I am not certain which is the module compartment---is this the large rectangular box connected to and immediately rearward from the fusebox?
If this is the module compartment, do I just pull out the fuse panel out of the way to access that area?
To safely lift the fuse panel from the box, do I need to remove anything else other than the 4 screws (two at front of box and 2 at the windshield side of the fusebox?
Is there enough slack to pull the fuse panel out of the box without worrying about dislodging something?
Sorry if I am acting stupid questions. I definitely do not want to screw something up by carelessness or ignorance and I am not finding any information or procedure on how to do this.
post #7 of 10 (permalink) Old 12-11-2009, 07:11 PM
aam
aam's Avatar
Quoted: 172 Post(s)
About four feet from the fuse box to the right.
Regards.
aam.
aam is offline
post #8 of 10 (permalink) Old 12-11-2009, 10:02 PM
wayneg's Avatar
Vehicle: 1999 SL500 Sport, Black Opal Pearl, Helios Leather, Pano roof, AMG Aero2 18"Split Rims, Rear Seats
Quoted: 27 Post(s)
There was not masses of slack on mine but enough to lift and gain room to splice into a +feed with a little care. My kit had built in fuses so I just picked up from the fattest live I could access easily.
wayneg is offline
post #9 of 10 (permalink) Old 12-13-2009, 06:16 PM Thread Starter
aam,
Is this the large lead you are talking about (identified by clamp at top in image 1a) and 1b?
Is it safe to splice this further toward the front at spot pointed by screwdriver (image 2)?
Thanks,
Roger
ID:	279136   Click image for larger version
ID:	279137   Click image for larger version
post #10 of 10 (permalink) Old 12-13-2009, 06:52 PM
aam
aam's Avatar
Quoted: 172 Post(s)
No, in your first picture where your clamp is move to the cars left about 6" where this hole/opening in your picture look doooown on the floor you will see the maybe red cable
it goers in a plastic box remove the cover and it is there.
Remember our cars run for 12 years, not all the connectors are located exactly
on the same spot, but you are getting there.
It is like making hmmm,,,, during the day it is easier, at night is a little harder to locate things, but if you follow the trail.......
Love pictures send more not close ups I like to see more of the field.
Regards.
aam.
aam is offline
    Joint Connecting Rod / Caster Box Diesel Power W126 S,SE,SEC,SEL,SD,SDL Class 11 01-25-2011 12:30 PM
    Small black box with Blue & White fuse in front of fuse box??? soltek W201 190-Class 2 09-14-2008 10:46 PM
    1985 300SD inline fuse from fuse box? hanknows W126 S,SE,SEC,SEL,SD,SDL Class 1 12-18-2007 02:26 AM
    Xenon HID for your Mercedes . (PHILIPS OEM HID)599 Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 12-30-2000 06:16 AM
    Xenon HID for your Mercedes . (PHILIPS OEM HID)599 JBC HID C208/A208 CLK-Class 0 12-29-2000 10:05 PM
