» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 10-26-2009, 01:00 AM   #1 (permalink)
1992300SL's Avatar
Date registered: Jan 2008
Vehicle: 1992 300 SL
Send a message via MSN to 1992300SL
Thinking of changing the air filter to K&N anyone ever change it to this one??
basically I want more power and I was thinking what it the easiest and economical so I was wondering if any of you guys have changed the air filter to k and n?? and seen any improvements I hear that its a good filter so I was just wondering.....
1992 300 SL (RED) 88k
2005 c240 4matic (SILVER)
1996 LEXUS LS 400 (DARK GREEN)
2004 YAMAHA V STAR CLASSIC TWO TONE.
2004 KAWASAKI EX 500
1992300SL is offline   Reply With Quote
Old 10-26-2009, 01:22 AM   #2 (permalink)
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 1995 SL500 - K&N Filters, Modified Intake, Modified ECU, Ported & Polished TB, HID Xenon Conversion
Good question indeed. However, this has been discussed at great length.
Instead of starting a new thread, why not consider this existing thread titled as Question on horsepower gain from K&N engine air filters?
Ken
NEOKEN is offline   Reply With Quote
Old 10-26-2009, 01:41 AM   #3 (permalink)
1992300SL's Avatar
Thanks man, this car is kinda slow I would love to put some power in it, I Love the car but cant take how slow it is...... maybe I should have got a 500..
Old 10-26-2009, 02:18 AM   #4 (permalink)
Date registered: Jun 2008
Vehicle: 2000 w203 c200k (Yes, it's a w203 from Germany)
An air filter is not going to turn a "slow" car into a faster one, or make miraculous improvements to the performance. If you are game, a different engine, turbo, or supercharger would do the trick, but an air filter will get you zero. Just keep your engine maintained, and a good stock filter will do the trick.
jerk_chicken is offline   Reply With Quote
Old 10-26-2009, 03:02 AM   #5 (permalink)
Date registered: Aug 2006
Vehicle: 1992 300CE
More in more out. More compression more power. just keep up to date w your tuneups and oilchanges as the aftermarket filters will filter less particles
1992 300CE
BilsteinSport
Vogtland
EuroLampsAllAround
2pc18"///AMGs & YokohamaS.Drives
FS: 5x112 15mm High Quality Spacers
FS/FT: 17" Staggered AMG 5-Spoke CLK Wheels and Tires
FS/FT: 18" Brabus Monoblock IV, 2pc
ronald7410 is offline   Reply With Quote
Old 10-29-2009, 10:41 AM   #6 (permalink)
Date registered: Oct 2007
Vehicle: 1992 300sl
I have a 92 300sl,signal red like yours. After I got the car two years ago I did all the filters, fluids, etc. I put in a K&N both for the performance hype and the ;longevity. I clean it every 6 months. Has it helped performance? I doubt it. The best change I have seen is when I recently put in new spark plugs. The car feels a bit better, but it is no V8.
jnf300sl is offline   Reply With Quote
Old 10-30-2009, 12:39 PM   #7 (permalink)
lazz's Avatar
Date registered: Feb 2008
Vehicle: 2001 SL500 AMG
I just insatlled K&N drop in air filters and boy was it a hassle. Just prying off the engine cover, air filter cover and then unscrewing the torx (sp?) screws was a lotta work. As far as performance goes.... NO INCREASE. Keep the engine tuned, oil clean and just keep your money.
lazz is offline   Reply With Quote
Old 10-31-2009, 08:51 AM   #8 (permalink)
Carlo$'s Avatar
Date registered: Sep 2003
Vehicle: 97 SL500
don't waste your $$$ with K&N. Save your $$ for an SL600.
http://xrl.us/benz1
Carlo$ is offline   Reply With Quote
Old 11-02-2009, 01:41 AM   #9 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: 2000 SL500 Sport
If you want to improve your performance when was the last time that you replaced the following parts?
Spark Plug Wire Set
Bosch F8DC4 Spark Plugs
Ant-Sieze and Dielectric grease for the plugs
Bosch Rotor Cap plus Seal p/n 03366 and 0149975848
Bosch Rotor p/n 04297
Bosch Fuel Filter p/n 71047
Std. Engine Air Filter Note: no need for K&N
Std. Cabin Air Filter while your at it p/n 1298350047
Always buy Bosch. Compare prices at
AutohausAZ and
Mercedes Benz Parts
lynns is offline   Reply With Quote
Old 11-02-2009, 08:33 AM   #10 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Well I was always dogging K&N filters, then I found out that my car had them
already in.
Oh yes, they where swimming in oil, had to blow some of it off, and clean the air box
out.
Regards.
aam.
aam is offline   Reply With Quote
Just did my Oil change & air filter change. What else does Service B entail? RaleighMB W210 E-Class 5 03-07-2009 07:39 PM
What will changing my air filter (like to K&N) do? timmynabenz W209 CLK Class 4 11-03-2008 02:11 PM
Changing the air filter (Need Advice) Smaily W201 190 Class 10 07-28-2007 07:51 PM
Changing Cabin Air Filter '97 E300... Change radio to IMPROVE sound michakaveli W210 E-Class 3 11-05-2002 08:56 AM
Need help changing air filter on SLK32. Anyone change their own.... Jeff R170 SLK Class 2 07-10-2002 05:21 PM
