Ok I have read all the post on how to pull and clear codes using an LED but I can't seem to duplicate the blinking LED like everyone else. I am guessing that I must be doing something wrong or else the car has a serious issue.
Here is my understanding on how one would read codes (I have a 38 pin):
And to clear codes:
Did I miss something in all the reading that I did on how to read codes? I can usually figure things like this out but not matter what I did (I tried flipping around the + and - positions on the LED) I never got a any blinking in fact the LED didn't light at all. The LED will light up just fine if I just connect it to the 12v and ground pins and it would also light up between ground and some of the other pins (but not all). I feel like I am missing a step or something....
- ignition on but car off
- jump wire between ground and pin that you want to read codes from (leave connected for 2-4 seconds)
- remove jump wire
- connect 12v LED + to 12v and - to pin that was just grounded w/jump wire (must be done within 2 secends of jump wire being removed)
And to clear codes:
- jump wire between ground and pin that you want to clear (leave connected for 8+ seconds)
