ASR LIGHT STAYS ON: 1993 500SL - Mercedes-Benz Forum
post #1 of 56 (permalink) Old 06-25-2009, 06:50 PM Thread Starter
Date registered: Feb 2009
Vehicle: 1993 Mercedes Benz SL500
Unhappy ASR LIGHT STAYS ON: 1993 500SL
Hello
My ASR light is on, I have checked the tires for proper air pressure and wear and they are OK. I then built the diagnostic code reader from this web site and connected to the ECU connection pins for testing the ASR circuit (socket 1: Ground) (socket 3: 12V) (socket 6: ABS/ASR output) for testing. The results were two faults: 21 flashes and 30 flashes. I have purchased the MB CD but cant find the fault code table on the CD. I did find find a fault code table on this web site and I think it's for my model car. It states 21 flashes is the Pressure Switch (A7/3s1) Charge and 30 flashes is the CAN data line to EA/CC/ISC module (N4/1). Wow, I dont have a clue what either one of those possible causes could be or where to begin. Any help into trouble shooting and solving this problem would be greatly appreciated.
Charlie
seller is offline
post #2 of 56 (permalink) Old 06-25-2009, 08:18 PM
hollerbox's Avatar
Date registered: Nov 2007
Vehicle: 1994 SL500
Search on 'wiring harness'...a common source of problems like this for 93-96 R129s:
PeachParts Mercedes ShopForum - View Single Post - wiring harness problem on SL600
Long story short: replace the wiring harness first and go from there.
hollerbox is offline
post #3 of 56 (permalink) Old 06-26-2009, 06:31 AM Thread Starter
ASR LIGHT 993 500 SL
Thanks, I will replace wiring harnesses, let me start researching engine harness suppliers for the best price.
Charlie
seller is offline
post #4 of 56 (permalink) Old 09-10-2012, 08:13 PM
Bimmerman4ever's Avatar
Date registered: Jun 2009
Vehicle: 99 Audi A8 Quattro 4.2 & 00 E320 4M
Quoted: 17 Post(s)
It's been a while. Ever find a wire harness?
Past Euros: 91 MBZ 300TE, 91 Jaguar XJS V12 Coupe, 94 Alfa Romeo 164 LS, 80 BMW 320i, 85 BMW 528e, 86 BMW 325e, 88 BMW 325e, 88 BMW 325i Cab, 89 BMW 325ix, 91 325i Cabrio, 93 BMW 740i, 94 BMW 740iL, 95 BMW 525i, 78 Fiat Spyder 124, 98 Land Rover D1 LSE, 93 MBZ 190E 2.6, 96 MBZ C280 Sport, 93 MBZ 400E, 90 MBZ 300ce, 92 MBZ 500SL, 71 MGB-GT, 91 VW Corrado G60
Bimmerman4ever is offline
post #5 of 56 (permalink) Old 09-11-2012, 06:51 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 307 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
there are no suppliers for harness, you can either rebuild yours, or buy one from the dealer.
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #6 of 56 (permalink) Old 09-11-2012, 09:05 AM
Quoted: 17 Post(s)
Any idea on wire size ?
post #7 of 56 (permalink) Old 09-11-2012, 09:14 AM
bayhas's Avatar
Quoted: 307 Post(s)
there is a about 70 wires in the harness, different sizes, 16-12AWG, I wouldnt recommend testing with your own, as most jacks require some experience to open properly, one mistake, and your car is a sitting duck...
contact BBA for throttle rebuild, and Alex for upper engine harness rebuild.
Garage:
Former Mercs:
bayhas is offline
post #8 of 56 (permalink) Old 09-11-2012, 09:17 AM
Quoted: 17 Post(s)
Is it typically the ETA that deteriorates or the main harness that goes first?
post #9 of 56 (permalink) Old 09-11-2012, 09:19 AM
bayhas's Avatar
Quoted: 307 Post(s)
both, although the ETA is a tad bit more insulated, but the upper engine harness does not affect the ASR/ABS operation, but rather, causes the car to run rough...
Garage:
Former Mercs:
bayhas is offline
post #10 of 56 (permalink) Old 09-11-2012, 09:26 AM
Quoted: 17 Post(s)
I see.
I tried to clear the ABS/ASR light by a couple methods I read.
Grounding pin 4 with 1 (38 pin) for 6-8 seconds ignition position 2
off 5 seconds, then pos 2 for 10 seconds then start
also the removal of the ground battery wire then shorting with a screw driver
to the positive lead
Neither worked. So I'm going to make or buy a simple 3 wire LED code reader and see if I can pull the codes and clear them out.
Instructions anywhere to make one?
(by the way same year 500SL a 93 with ABS/ASR on and top problems)
ASR LIGHT 1993 500SL seller General Mercedes-Benz 5 07-02-2009 09:06 PM
1992 500SL ABS/ASR light stays on at start-up 92sl500 R129 SL-Class 10 11-11-2008 03:45 AM
ASR and ABS indicator light stays on, on my 93 SL500 Strick9 General Mercedes-Benz 0 10-17-2008 03:06 PM
92 500SL ASR Light charris130 R129 SL-Class 1 09-19-2007 05:45 AM
1993 600 sl asr light peter hamlett R129 SL-Class 0 08-06-2003 08:13 AM
