» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-17-2009, 04:15 PM   #41 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: 2000 SL500 Sport
Originally Posted by chriswufgator View Post
I always thought there was a filter... Anybody know the p/n for it? NO
I'd like to replace it when I do my flush.
I've never been called to disassemble a RST hydraulic pump from it's reservoir and was unaware until now that there is a filter within the >1998 pump reservoir. The only problem is that in order to R&R the filter you need to disassemble the reservoir from the pump to get at the filter and I'm not sure if it's worth it to clean or replace.
The <1998 boxy reservoir filter looks easier to clean than the >1998 cylindrical reservoir filter.
lynns is offline   Reply With Quote
Roadster Soft Top (RST) hydraulic system fluid renew for MY 97-02 RedLiner R129 SL Class 53 10-06-2009 08:19 PM
diagnosing a faulty roadster soft top controller on a 1996 stewedg R129 SL Class 39 08-05-2009 09:11 AM
Unlocking the roadster soft top (RST) hatch ? jmerc6 R129 SL Class 1 07-01-2009 05:45 PM
How to remove the hard top and put the RST(roadster soft top) up manually lynns R129 SL Class 7 04-27-2009 10:53 AM
Roadster Soft Top - RST Spring Fever lynns R129 SL Class 4 04-06-2009 10:14 PM
