Cruise Control Function Fixed - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 03-24-2009, 08:54 AM Thread Starter
morriswu's Avatar
Date registered: Aug 2006
Vehicle: 300SL-24 1992 White;BMW X3-3.0 E83 2005 Blue;190E-2.6 1992(sold); BMW 316-1.8 E30 1983(sold)
Quoted: 6 Post(s)
Hi friends,
I am to share the experience of fixing the c/c function.
The cause of my c/c malfunction is the bad c/c amplifier. I replaced it with a W124’s and test the function for 2 weeks. It works so far so good.
The R129’s c/c amplifier can substituted by W124’s and the big benefit is: saving money! This used w124’s amp. only costs me us$30.
Hope this finding is helpful to the forum.
Regards,
morris
ID:	229066   Click image for larger version
ID:	229067   Click image for larger version
ID:	229068   Click image for larger version
morriswu is offline
post #2 of 15 (permalink) Old 03-24-2009, 08:58 AM Thread Starter
morriswu's Avatar
Quoted: 6 Post(s)
(more pictures)
ID:	229071   Click image for larger version
ID:	229072   Click image for larger version
ID:	229073   Click image for larger version
ID:	229074   Click image for larger version
morriswu is offline
post #3 of 15 (permalink) Old 03-24-2009, 10:36 AM
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 95 SL500, K&N, NEOKEN Ported TB, Custom Intake, RENNtech Sport Exhaust, AMG I Monoblocks
Quoted: 30 Post(s)
Hi Morris, thank you for posting up the details and photos!
I am sure this information will be useful to the next member down the line.
Best Regards.
NEOKEN is offline
post #4 of 15 (permalink) Old 03-25-2009, 10:54 AM
Date registered: Oct 2007
Vehicle: 1992 300sl
Quoted: 2 Post(s)
Thanks Morris,
My 92 300sl cruise control has worked only a few times in the last year. Is this the fix I should try? Where is the amplifier located? It looks like a plug and play...is that all there is to it? Where should I look for the part in the US?
Anyone else out there that has experienced an intermittent criuse control?
jnf300sl is offline
post #5 of 15 (permalink) Old 03-25-2009, 11:10 AM
NEOKEN's Avatar
Quoted: 30 Post(s)
Hi inf300sl, are you running on OEM spec. wheels and tires, or do you have aftermarket wheels? There have been members with the incorrect size wheels / tires which is also known to cause a malfunction in the cruise control system.
Here is one example:
http://www.benzworld.org/forums/r129...995-sl320.html
Best Regards.
NEOKEN is offline
post #6 of 15 (permalink) Old 03-25-2009, 12:17 PM
RoadKing's Avatar
Date registered: Sep 2007
Vehicle: 2007 CLS 550, 1998 Harley Road King, 2011 F-150 EcoBoost, '65 Shelby Cobra
Is the CC module for a 1992 300SL the same as a 500 SL? If so, where is it mounted?
Mike
I don't downshift often, but when I do, it is next to a Prius so I can show them how I am hurting the environment! -
'07 CLS 550
RoadKing is offline
post #7 of 15 (permalink) Old 03-26-2009, 08:59 AM
Vehicle: 1992 300sl
Quoted: 2 Post(s)
Thanks Ken,
My 300sl is bone stock with original wheels and standard issue size tires. On a very few ocassions the cc has operated properly, but so many times it would not opperate that I have stoppped trying. I have heard that putting in new fuses will often help solve the problems of intermittent operation.
What else copuld be causing the trouble? I am driving the car to Florida tomorrow and will try the cc again.
Jack
jnf300sl is offline
post #8 of 15 (permalink) Old 03-26-2009, 09:10 AM Thread Starter
morriswu's Avatar
Quoted: 6 Post(s)
Originally Posted by jnf300sl View Post
Thanks Morris,
Hi jnf300sl,
The c/c amplifier's position is shown as the attached. It is beside the MAS unit.
My c/c's symptom is similar to yours: intermittent, sometimes engaged, sometimes not. After I replaced the amplifier, everything is going fine.
The car junk yards might be plentiful of w124’s c/c amplifiers, you can go and find one.
Good luck,
morris
morriswu is offline
post #9 of 15 (permalink) Old 03-26-2009, 02:52 PM
Vehicle: 1992 300sl
Quoted: 2 Post(s)
Thanks Morris,
I am on my way to the junkyard!!
Jack
jnf300sl is offline
post #10 of 15 (permalink) Old 03-26-2009, 08:01 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 171 Post(s)
On the R124 programa says something about codes.
Did you have to work on that?
I can't find any info for R129's.
Also I don't know if it's the same CC for 500 and 600
Regards.
aam.
aam is offline
    I fixed my cruise control!! St3ve W124 E,CE,D,TD Class 52 09-16-2015 04:12 PM
    Fixed Cruise Control breastroker W140 S-Class 6 08-18-2007 02:14 PM
    I fixed my cruise control! paulb W124 E,CE,D,TD Class 0 06-22-2007 05:29 AM
    Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK-Class 42 01-15-2006 02:37 PM
    Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 10:34 AM
