Hello All,
I believe that I am in need of an engine wiring harness for my 93 sl500.
From all of the posts that I have gone through on this site, I am led to believe that this is what needs to be replaced to rectify the problem:
Problem:
Originally ASR light would go on occasionally, now it will not turn off, throttle is not overly responsive, very sluggish to drive(limp home mode). Exhasut fumes are definately a different smell. I will also mention that before the SSR light was constantly on that there would be the odd time where the soft top would not work properly, (if this is not related to the engine wiring harness I can deal with it after the replacement of the harness).
I have tried the basics i.e. disconnecting the battery, currnetly the traction control does not work either.
I am located in Calgary Alberta Canada, any options besides the dealership on where I can get an engine wiring harness. Also what would the expected cost be.
It seems fairly straight forward to replace so I am planning on doing this myself.
1993 SL500
58000kms
w/body kit
lowered
imported from Japan
location Calgary Alberta Canada
Problem:
1993 SL500
58000kms
w/body kit
lowered
imported from Japan
