» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 03-08-2009, 10:41 PM   #21 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: 2000 SL500 Sport
Autozone Duralast 49-DL Battery
Originally Posted by bobterry99 View Post
For value I think it's tough to beat the red Autozone Duralast battery that Albert mentioned.
Please see Autozone Red Duralast p/n 49-DL Battery / Warranty - 2 yr. free / 7 yr. prorated, cost $89.99 plus $12.00 core and tax.
lynns is offline   Reply With Quote
Old 03-08-2009, 11:20 PM   #22 (permalink)
lynns's Avatar
digital volt gauge to put in the cig. lighter
Originally Posted by aam View Post
While in the store look for a digital volt gauge you connect in the cigarette lighter, $12.00 is what our cars are missing.
When you start the engine look at that, for a voltage drop.
And then how long it takes for to go back to normal.
It will tell you the condition of your battery the sooner the newer the battery is.
I am going to get one, I like to know what my electrical system is doing.
Great idea. Is it the Vector 12 Volt Lighter Plug Type LCD Battery Tester p/n VEC008 for $12.99 that your are referring to?
Will it fit in our cig. lighter socket?
Old 03-09-2009, 04:02 PM   #23 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Yes lynns I think that that's the one.
There is no available picture on your post.
I did see it about 6 months a go, I did mention about it on an other post.
But as you know by now, I am working from memory, and part numbers are not my
strong hold.
It should work, the lighter plugs are universal if a cell phone adapter works the
tester should also.
I did mentioned that I have made from an old cigarette adapter to my
multimeter so I can read the voltage, but that unit is easier to work with.
Who needs lose wires in the car.
I also think that I should rig an amp & voltmeter in the trunk, but I haven't found a spot to be out of the way yet.
That is why I haven't bought the autozone gauge yet.
As far as the glass absorb battery goes I have nothing against them, only the price.
One day we all are going to have them, at a cheaper price. ( Mass produce.)
For many reasons, one is commercial transportation, workers, and public safety.
The other is marketing we will be able to order on line, and have it
delivered home at a reasonable price, now I like that. LOL.
Regards.
aam.
PS.
I still don't like the idea, of not been able to do my tests. Hahaha.
aam is offline   Reply With Quote
Old 03-10-2009, 02:57 AM   #24 (permalink)
lynns's Avatar
Look what this guy did with his Battery! and this 12 Volt Antizap Surge Protector w/ LED for $13.95.
Old 04-08-2009, 09:59 PM   #25 (permalink)
lynns's Avatar
Originally Posted by lynns View Post
Albert, I went to my local Autozone store today and bought the following item thanks to you.
I then plugged the Vector 12 Volt Lighter Plug Type LCD Battery Tester p/n VEC008 for $12.99 into my cig lighter, ignition ON. I received a stable 12.2 volt baseline reading.
BTW, I received a 13.7 volt reading with the engine running. When I turned the engine off the reading went to 12.5 volts and stabilized again at 12.2 volts.
Old 04-09-2009, 03:24 AM   #26 (permalink)
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
lynns I can read the battery voltage in my CL 500 using the secret menu in the COMAND radio unit and I see a stable 13.7 volts reading when the engine is running and more or less 12.2 ~ 12.5 volts when the engine is not running so either my battery is going south too or the readings are normal. What do you think?
Cheers.
I drive like I stole . . . YOURS
msbarsi is offline   Reply With Quote
Old 04-09-2009, 09:53 AM   #27 (permalink)
lynns's Avatar
Mick, thanks for your response. Good to hear that your getting the same, 12.2 ~ 12.5 volts when the engine is not running and the ignition key is in sterring lock position 2. I checked my reading this morning an got 12.2 volts in position 2 and when I turned the key to postion 3 it dropped to 12.0 volts.
Quite honestly I don't know what a NEW battery is supposed to read, when the engine is NOT running, so I was hoping that Albert or someone else would chime in.
Old 04-09-2009, 02:02 PM   #28 (permalink)
Date registered: Jan 2006
Vehicle: 00 SL500, 09 Silverado 4x4 LTZ,John Deere 318
Smile
12.2-12.5 is NORMAL!!!!(with key on, no engine running) Depending on how long the car has been sitting, when first started, a volt-meter placed on the battery terminals should read ABOUT 13.5-13.9 It would NOT be unusual to see as much as 14.5V for a short time before dropping back to a normal level.
drags1998 is offline   Reply With Quote
Old 04-09-2009, 03:42 PM   #29 (permalink)
aam
aam's Avatar
Hahaha.
Lynn, your post came after I left, it's TV time.
So here it goes.
You have a battery that is still good, but it is about 3-4 year old. (Like mine.)
We are on the same boat.
My battery factory date mark is 03, don't ck the sticker they lie.
Glasses on, eyes on the gauge while cranking, you will see a voltage drop,
and the low LED is on, then the high also, and after a while of driving,
they go off.
Keep an eye on the gauge, for now we are OK, but in summer time we most likely get in trouble.
( California, no winter here. )
Maybe we can squeeze a year and half, I don't think that we will be able to pass the second summer though.
As you know, I don't waste money, so no new battery yet.
If you can notice, the car takes a little longer to start then normal.
About the little battery thingy, it may not work on our cars, or not from the lighter
any ways.
From the radio fuse maybe, it is a $100K Mercedes so nothing is easy.
A new battery fully charged normal temperature has 2.1 v. per cell =12.6
Now if you drive the car non stop for a few hours you may see that
on your battery.
But it's like early in the morning.
Whaaaat?
Hmmmmmm.
I wonder if the rest of the guys know what I am talking about.
Regards.
aam.
PS.
Now why I have a feeling that your ignition switch is going
south?
Old 05-04-2009, 08:51 PM   #30 (permalink)
Thorgod's Avatar
Date registered: Jul 2005
Vehicle: 1995 SL500
Guide Sign Position P/N 140.584.6817
Thor, would you please post a picture, from a distance, of where you located the new decal?
Per Lynns' request for a pic to locate the exact position of the "BATTERY IN TRUNK" guide sign p/n 1405846817. The close up of course is after installation of the new sign. There was enough glue residue to position it exactly in the original location. The full engine pic was enhanced with MS Paint with the yellow line to simulate it's position on an older pic taken before I got the new sign. I think you'll get the idea. However Lynns, I believe the cover changed from 1996 on, mine was a 1995. Double check with someone with the same year as yours to be sure of it's position...............Thor
1971 350SL 4-speed stick
1979 300CD
1985 300D
1989 560SL
1994 E320 wagon
1995 SL500- 46,000 mi.
2004 Land Rover Discovery- 28,000 miles
Thorgod is offline   Reply With Quote
Battery Light On: Changed Regulator + Battery... STILL ON! sightless R170 SLK Class 6 06-18-2008 03:12 PM
alternator lead at battery 2007 vito snatch V-Class 0 11-16-2007 09:55 PM
SL 55 Battery Acid Exploded need help? pfgray R230 SL Class 3 08-31-2007 03:26 PM
Battery replacement info.....which battery etc? Black98SLK230 R170 SLK Class 7 12-06-2004 09:31 AM
Key fob battery died, is battery replacement covered under warranty? S4toML W163 M-Class 2 07-13-2004 09:14 AM
