Trouble Code P1519 - Adjustable Camshaft Timing Solenoid - Mercedes-Benz Forum
post #1 of 32 (permalink) Old 01-15-2009, 03:51 AM Thread Starter
Dimitris's Avatar
Date registered: Aug 2008
Vehicle: '02 Mercedes SL500 Silver Arrow
Quoted: 10 Post(s)
Post Trouble Code P1519 - Adjustable Camshaft Timing Solenoid
Since i got the car 08/2008 i havent get to drive it more than 2000 miles without the CEL coming on. I was driving home from work last night and the CEL came on. I read the codes and this time i got P1519. After a search i found that this might be idle Air Control Valve Circuit Failure. I really dont know where to start and what to check first. Anyone had that code before?
Thank you in advance
Dimitris is offline
post #2 of 32 (permalink) Old 01-15-2009, 04:15 AM
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 95 SL500, K&N, NEOKEN Ported TB, Custom Intake, RENNtech Sport Exhaust, AMG I Monoblocks
Quoted: 30 Post(s)
Hi Dimitris.
Just spoke with my ASE certified technician with regards to diagnostic fault code P1519.
This is what he pulled from their references:
P1522 Mercedes LH Adjustable Camshaft Timing Solenoid
P1519 Mercedes RH Adjustable Camshaft Timing Solenoid
Perhaps we can get a third opinion from other forum members for further verification?
Thanks in advance.
NEOKEN is offline
post #3 of 32 (permalink) Old 01-15-2009, 06:17 AM
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Quoted: 8 Post(s)
Send a message via Skype™ to msbarsi
Dimitris I'm sorry to hear you are getting problems but as a start I would clean the MAF just in case. MAFs on our cars seem to be a little troublesome or at least delicate and from what I understand they seem to get dirty fairly easy so the code you got even if it's not related to the MAF might be caused by it. If you do an advanced search on the forum for MAF cleaners you'd get the names of some good ones and if memory assists me a good one should be from CRC or something.
Cheers.
I drive like I stole . . . YOURS
Last edited by msbarsi; 01-15-2009 at 08:21 AM. Reason: Mispelled the MAF cleaning spray brand
msbarsi is offline
post #4 of 32 (permalink) Old 01-15-2009, 07:44 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '91 300SL, '91 500SL, '00 S500, '96 C220
Quoted: 212 Post(s)
I agree with Ken. I would check the operation of the left-hand timing solenoid with a basic electronic multimeter. The test procedures are given in the engine diagnostic manual contained in both the Mercedes WIS and R129 Tech DVD.
bobterry99 is offline
post #5 of 32 (permalink) Old 01-15-2009, 09:46 AM
NEOKEN's Avatar
Quoted: 30 Post(s)
Thanks Bob for the confirmation.
Much appreciated!
NEOKEN is offline
post #6 of 32 (permalink) Old 01-15-2009, 11:19 AM Thread Starter
Dimitris's Avatar
Quoted: 10 Post(s)
Thank you all guys for the help. Its much appriciated. I think its time to get this DVD. I cleared the light and i ll see if it comes back on. Mbarsi you are right about how troublesome is the Maf. I cleaned it with CRC MAF cleaner just 2.5K miles ago. Maybe its time for a new one
Dimitris is offline
post #7 of 32 (permalink) Old 01-15-2009, 11:26 AM
msbarsi's Avatar
Quoted: 8 Post(s)
Dimitris as aam says the CRC spray is only a temporary fix because sooner or later MAFs do fail and they need to be replaced and if you already cleaned it and it only lasted 2,500 miles you need to start shop around Ebay (yes Ebay) for a new Bosch one. There are a lot of infos about our MAF in the forum to help you pick the right one so it's time to do some shopping for you.
Cheers.
msbarsi is offline
post #8 of 32 (permalink) Old 01-15-2009, 02:33 PM
Myndex's Avatar
Date registered: Jan 2009
Vehicle: 1980 450SL named Freya. 202,000mi
Quoted: 140 Post(s)
Wow - these engines have solenoids that adjust cam timing?
A
Myndex is offline
post #9 of 32 (permalink) Old 01-15-2009, 03:36 PM
NEOKEN's Avatar
Quoted: 30 Post(s)
NEOKEN is offline
post #10 of 32 (permalink) Old 01-21-2009, 06:45 AM Thread Starter
Dimitris's Avatar
Quoted: 10 Post(s)
Cleared the CEL and put 200 miles on the car since then. The light didnt came back on . She runs very strong.
We ll see what happens
Dimitris is offline
P1519 code RonDim W140 S-Class 0 11-15-2008 05:25 PM
Trouble Codes P0455 and P1519 artlharris R129 SL-Class 2 04-01-2007 12:24 PM
1993 Benz 300SE Camshaft Timing Adjust Solenoid Sensor dbmoylan W140 S-Class 3 01-29-2007 01:11 PM
camshaft timing solenoid? jjcarr W202 C-Class 2 07-16-2006 05:34 PM
trouble codes P1525 and P1519 tefields31 W202 C-Class 0 04-18-2006 08:04 PM
