» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 08-21-2008, 11:58 PM   #21 (permalink)
GUSMB's Avatar
Date registered: Nov 2005
Vehicle: MB SL600 -93, MB SL600 -94, BMW 540i -97
Send a message via ICQ to GUSMB Send a message via MSN to GUSMB
Removed the cylinders maneuvering the lid aswell, located in the trunk:
Same construction, only longer:
Apart:
Time to visit Momentum to see if they have the seals.
More pictures:
Takhydraulik 080821
From 32 to 12 cylinders in 1 month...
MB SL600 -94
My rides
GUSMB is offline   Reply With Quote
Old 08-27-2008, 03:07 AM   #22 (permalink)
GUSMB's Avatar
Monday the seals arrived, they were ,uch harder then the previous I used, more like the original ones. Outer dimensions is to wide, was not able to press them in place. A temporary lathe made from a dremel and a drill:
Machined it down to 13 mm:
Before/After:
New/Original:
In place:
Mounted:
Old 08-27-2008, 04:05 AM   #23 (permalink)
GUSMB's Avatar
Mounted all four cylinders, tested and found two other small ones pouring out oil. Took one of them out of the car, interesting mounting:
The Top of it is a screw on plug with two small holes in it, almost impossible to unscrew. Both pieces in alumiunium and also glued/locked.
After a while I realised I had destroyed it, then used a lot more force to get it apart to se how it was constructed. Result, damaged axel and destroyed screw-on top:
Price is just above $600 in Sweden, anyone knows of a used one?
Part no is 1248000272, aparently also in CE-convertible.
Sent Dennis a PM about fixing the other one, no reply yet.
Old 08-28-2008, 02:10 AM   #24 (permalink)
Date registered: Aug 2006
Vehicle: 300SL-24 1992 White
Hi GUSMB,
You need either the makeshift tool or needle nose pliers plus heat as in the attached pictures.
good luck,
morris
morriswu is offline   Reply With Quote
Old 08-28-2008, 02:17 AM   #25 (permalink)
GUSMB's Avatar
Originally Posted by morriswu View Post
Hi GUSMB,
You need the tool as attached pictures.
good luck,
morris
Thank you, exactly what I was thinking of constructing this weekend.
Any tips on how getting the top of the axel off without damaging the axel?
Still need to find a new Cylinder since I broke it.
Old 08-28-2008, 07:43 AM   #26 (permalink)
Hi GUSMB,
Do you mean the square block screwed on the top of the rod?
You have to heat up the thread portion with a cigratte lighter to melt out the glue. Also clamp the rod carefully with some thick cloth or rubber between for protection.
You will meet the same difficulty in dealing with the 2 big cylinders.
I would try to find some pictures for you.
good luck,
morris
Old 08-28-2008, 07:59 AM   #27 (permalink)
GUSMB's Avatar
No problem then familiar with the process.
Just thought if there was a better idea, but will try using lots of cloth.
Old 09-01-2008, 07:32 AM   #28 (permalink)
GUSMB's Avatar
Made it easy for me, took all the cars out of the garage and simply took the next one...:
Got all winter to find a new cylinder and module.
Old 09-01-2008, 09:33 PM   #29 (permalink)
ahmorris's Avatar
Date registered: Oct 2002
Vehicle: '97 SL500 & '01 ML320
Originally Posted by w8n4ya View Post
what should I use to cap the hydraulic lines while the cylinders are in for repair? My car is my everyday driver, so the objective is to not have the mineral oil leaking all over.
I had leaking cyclinders and was going to tackle it, but as you it's my daily driver hence decided to have it fixed when on vacation instead. I had the same question on capping the lines and most people said no need to do if one drains the fluid from the reservoir. It's not under pressure hence taping line ends should stop minor leaks.
Regards
Alan
1997 Benz SL500 (R129)
2001 Benz ML320 (W163)
HONG KONG
ahmorris is offline   Reply With Quote
Old 09-01-2008, 11:07 PM   #30 (permalink)
GUSMB's Avatar
Regards
Alan
I did the same, if cylinders are leaking you already have a fair amount of oil everywhere the top goes. Probably the system would have "drained" itself from the leak, just taped the ends until repair.
New seals for soft top cylinders KBelov R129 SL Class 1 05-10-2009 09:59 AM
Would you be interested in a complete DIY set of seals for all 12 RST cylinders? lynns R129 SL Class 44 02-28-2009 06:21 PM
Lock Cylinders jaybro R129 SL Class 1 05-13-2006 02:32 PM
Rebuild top "lockdown" cylinders??? fergusj R129 SL Class 4 08-16-2004 08:53 AM
Repairable diff lock slave cylinders? Irish sean G-Class 7 12-18-2001 07:06 AM
