First of all read the Blue Stickies at the top of the forum. They answer many of the questions that have been asked over and over. Even if they do not pertain to your situation at this time. If you do not find an answer to your present question it is absolutely necessary that you get familiar with the 'Search' and 'Advanced Search' function located on the right side at the top of the forum. I have attached JPG's so you can see what they look like. Note: click on the two JPG's in order to enlarge.
Example: type in the word 'speaker or grill' then 'speaker grill' and read the posts in the R129 Forum. If that doesn't satisfy go to the 'Advanced Search' function left side to 'Search Titles Only' or use the pull down to 'Search Entire Post' then on the right side 'Search the R129 Forum' default or as a last ditch effort 'Search all of the Forums' and be prepared to read. Because BenzWorld is an International forum you will find that it is very mature and has a lot of great information . Especially with regard to the information collected on the 1990-2002 R129 SL.
Here are two examples that I found from searching and reading!
Please see how to remove the door panels and door speaker grill recovered
