Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 09-22-2008, 10:42 AM   #1 (permalink)
lincoln's Avatar
Date registered: Oct 2005
Vehicle: 97 SL500
MY97 door latch striker plate torque spec for the T40 Torx
screws that hold the door latch striker on the door jam??? I need to adjust mine and want to be sure to get it in spec.
97 SL500 - Silver/Ash, 19" ASA ST2, Passport SRX stealth install, Clifford G5, Llumar Clear Bra, 20% Tint, Bilsteins.
99 Chevy Silverado ECSB LT Z71 - very modded
08 GMC Sierra Denali - White/Ebony, lots of mods
03 SL55AMG - Silver/Charcoal Pano - Dealership demo
lincoln is offline   Reply With Quote
Old 09-22-2008, 10:59 AM   #2 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: MY00 SL500 SL2
Snug! Shoot for 12.5 (lbf/ft)
Regards, Lynn S.
MY00 SL500 triple black Sport
MY89 560SL triple blue SOLD
MY88 560SL white on tan SOLD
lynns is offline   Reply With Quote
Old 09-22-2008, 01:48 PM   #3 (permalink)
Date registered: Jan 2006
Vehicle: 00 SL500
Smile
Tight!!!! (just to be different)LOL!!! Don't worry about TORQUING these bolts, Tight is close enough!!!!!! If your not sure what "Tight" is, Let someone else do it!!!
drags1998 is offline   Reply With Quote
Old 09-22-2008, 03:20 PM   #4 (permalink)
lincoln's Avatar
Vehicle: 97 SL500
I'd like a specific answer b/c the drivers was tight after the shop adjusted the striker but after a few months, thier version tight, was not tight enough and came loose. I have them as tight as I can get them with a hand tool on the drivers side but it's not nearly as tight as the passenger side which has never been loosen (but needs it since that side also needs a small adjustment). I picked up a 3/8" socket driver Torx set today, so I'll have more leverage to loosen/tighten these screws but I don't want to snap them off or strip them trying to make them as too tight.
This is the door latch on a roadster, so it being tight enough without breaking the screw is an important safety issue in my eyes.
Old 09-22-2008, 03:47 PM   #5 (permalink)
msmith66's Avatar
Date registered: Jun 2007
Vehicle: 1998 SL500 SL2/Pano
17 +/- 3 Nm = 10.32 to 14.75 Pound Force Foot(lbf/ft) Shoot for 12.5 (lbf/ft)
msmith66 is offline   Reply With Quote
Old 09-22-2008, 04:01 PM   #6 (permalink)
Date registered: Aug 2006
Vehicle: R129, W163, & W124
Originally Posted by lincoln View Post
the passenger side which has never been loosen (but needs it since that side also needs a small adjustment). .
Loosen the passenger side (that has never been loosen) using a torque wrench and note the lbs.number at which it breaks loose. Use the same lbs. number to tighten. I use this approach only if I'm certain that lock tite (or other sealant) was not applied to the bolt (or nut) when it was installed.
Also, you may want to put (or replace) a lock washer to keep the bolt tight in place.
Good luck.
edcarls is online now   Reply With Quote
Old 09-22-2008, 06:17 PM   #7 (permalink)
Vehicle: 00 SL500
Talking
Break-away torque will ALWAYS be higher than tightning torque.I don't have the correct # that your looking for,but I wouldn't go more than about 30 Lbs. The good thing about Torx heads is, the tool will break before the bolt will.
Old 09-22-2008, 07:25 PM   #8 (permalink)
msmith66's Avatar
For heaven's sake guys... I posted it straight out of the manual for him in post #5.
Old 09-22-2008, 07:39 PM   #9 (permalink)
lynns's Avatar
Originally Posted by msmith66 View Post
17 +/- 3 Nm
I will never understand how you, I, or others can post an answer and it becomes invisable for some reason.
The other thing I don't get is when someone posts a question it seems like we do the right thing by posting the answers and they never come back for the answer and if they do they don't read the above but instead say I don't get it.
Old 09-22-2008, 07:42 PM   #10 (permalink)
msmith66's Avatar
Hell Lynns, its just the nature of these things...
transmission pan torx bolt torque yumling W210 E-Class 6 04-19-2008 10:23 PM
Diesel injector torque spec?? Ron Conway W124 E,CE,D,TD Class 2 04-16-2008 06:38 PM
Need a torque spec..... Working on it right now.... :) billabongo W126 S,SE,SEC,SEL,SD,SDL Class 6 08-19-2007 11:02 PM
What torque spec for the lugs??? lincoln R129 SL Class 1 01-13-2006 05:23 PM
Striker on rear door - part no ( full size rear door ) petermerle G-Class 4 11-12-2003 03:28 AM
