1992 500Sl Check Engine light comes on - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-14-2008, 11:57 PM Thread Starter
Date registered: Jun 2003
I have a 1992 500SL. the check engine light came on recently. I disconnected the battery for 5 minutes and the light went away. After 100 miles and a couple of weeks later, the check engine light came back on. Can someone kindly advise me what to do please.
I have a 16-pole diagnostic connector: do I read the codes by first shorting poles 1 and 3, and then connect the LED light between poles 3 and 16?
And do I read the second code by repeating this procedure ?
Thanks.
1992500SL is offline
post #2 of 9 (permalink) Old 09-15-2008, 03:13 AM
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Quoted: 8 Post(s)
Send a message via Skype™ to msbarsi
Thanks.
Hi 1992500SL I can't remember if in 1992 there was already the MAF sensor in your car so I might be wrong but all the symptoms lead me to think that your MAF is going to need to be replaced.
Please someone correct me if I am wrong.
Hope this helps tho.
Cheers.
I drive like I stole . . . YOURS
msbarsi is offline
post #3 of 9 (permalink) Old 09-15-2008, 06:07 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '91 300SL, '91 500SL, '00 S500, '96 C220
Quoted: 147 Post(s)
Connect the LED first and leave it connected. Short #1 to #3 for 3 seconds and count the blinks. Short again for 2 seconds to read the next code, or short for 7 seconds to erase the one just read.
No MAF in this car.
bobterry99 is offline
post #4 of 9 (permalink) Old 09-15-2008, 08:20 AM
RoadKing's Avatar
Date registered: Sep 2007
Vehicle: 2007 CLS 550, 1998 Harley Road King, 2011 F-150 EcoBoost, '65 Shelby Cobra
I had a recurring CEL in my '92. Reset and it was ok for about two weeks. Then it was back. I was on my way to expensive parts replacements and diagnostics when my indy found a cracked vacuum line. By the time it was over, all the vacuum lines were brittle and cracked. This caused lots of vacuum leaks and the CEL. Vacuum lines are cheap and easy to replace.
There is also a modulation valve on your smog pump. Replace it as it may also contribute to the problem.
No more CEL for the past year.
Mike
I don't downshift often, but when I do, it is next to a Prius so I can show them how I am hurting the environment! -
'07 CLS 550
RoadKing is offline
post #5 of 9 (permalink) Old 09-15-2008, 12:34 PM Thread Starter
Bob,
Since I have disconnected the battery and the check engine light went away, am I correct to say that the code(s) is gone and I will have to wait until the check engine light comes back on again before I can read the code ?
Also, If a vacuum line is "open", the idle should go up, right ? but my rev stays quite steady at 600 rpm, give and take.
In my Volvo, a new fuel cap always solve the check engine light problem. Do you think a new fuel cap might help too ?
Thanks,
Alex.
post #6 of 9 (permalink) Old 09-16-2008, 10:21 AM
RoadKing's Avatar
Vacuum lines affecting idle
My broken and cracked vacuum lines did not affect idle. I was also steady at 600 rpm. You have a 16 year old car just like mine. Those lines are plastic. Unless they have been replace already, the engine heat alone has deteriorated them to egg shell consistancy.
Mike
'07 CLS 550
RoadKing is offline
post #7 of 9 (permalink) Old 09-16-2008, 12:05 PM Thread Starter
Roadking,
Yes I need to check all the vacuum lines. They were all replaced a couple of years ago but because my radiator is old, my car is constantly running between 100C to 105C which would make "egg-shell" much quicker. I am having the radiator replaced this weekend.
Going back to the vacuum lines, did you open all the plastic covers and visually check them, or did you use a tool to check.
Thanks,
Alex.
post #8 of 9 (permalink) Old 09-16-2008, 04:02 PM
RoadKing's Avatar
We used a tool. we hooked each up to a hand vacuum pump with a gauge. Pump a couple times and hold. If the vacuum decays you have a bad line.
If you replaced them all, you may want to have your indy check the vacuum modulator on you smog pump. It is along side the pump on the lower right hand side of the engine. There are a couple of rubber hoses that attach it. They can also go bad.
Mike
'07 CLS 550
RoadKing is offline
post #9 of 9 (permalink) Old 09-17-2008, 01:47 PM Thread Starter
Roadking,
Great, will check this weekend along with the radiator replacement.
thanks.
alex.
    1992 500SL ABS/ASR light stays on at start-up 92sl500 R129 SL-Class 10 11-11-2008 04:45 AM
    1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 10:19 PM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 03:37 PM
    Engine tuning parts - 1992 500SL catboy R129 SL-Class 0 02-13-2006 04:53 AM
    Check Engine light - 1992 2.6 Guest (MBNZ) W201 190-Class 2 02-14-2002 07:14 PM
