SL600 Mild Tuning - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 09-11-2008, 05:54 AM Thread Starter
Date registered: Jul 2007
Vehicle: 2006 SL65
SL600 Mild Tuning
For anybody that's interested. I replaced my 95 SL500 in March this year with a 96 SL600. I was planning to do a bit of tuning on the 500 but when I drove the 600 I was completely smitten - so change of plans. Anyway I decided that I needed to hear the engine, so the first thing to go was the standard exhaust. I had a custom system made here in Johannesburg by a specialist company (TNT Performance Exhausts), but nothing too extreme as I still wanted to be able to drive on the highways in relative peace. Then I added a set of K&N air filters, and finally had the ECU upgraded using a pair of Unichips with custom mappings by RG Motorsport. I am a very happy person with the results. I think MB was very conservative with their SL600 mappings as they needed to differentiate between it and the SL60. My wheel HP went from 268 to 311 - equating to about 450hp at the flywheel at sea level. Before I get flamed for my calculations, we are at an altitude of around 5500ft here in Johannesburg, resulting in an approx 18% power loss for normally aspirated engines.
Anyway the results on the road are better than I hoped for. The car sounds great and feels so much faster. I not going to say it has been transformed because I thought it was brilliant before, but now it's just so much better.
bflannigan is offline
post #2 of 27 (permalink) Old 09-11-2008, 06:37 AM
chriswufgator's Avatar
Date registered: Oct 2007
Vehicle: MB SL600, MB 380SE, Suzuki Grand Vitara, 38' Chris-Craft, Volvo V70XC, and my own two feet...
Quoted: 2 Post(s)
Send a message via AIM to chriswufgator
Nice, what did you do with the exhaust specifically? Got any pics?
Also, I completely agree with you that the stock tune on the SL600 leaves a lot to be desired. The a/f ratios can be richened by almost a full point at WOT, and can be leaned out half a point or so during most of the rest of the range, without causing any problems. The timing is also very retarded, and you can advance it significantly with no issues as long as you use premium fuel.
Stuartknight gained 40hp just from an ECU tune, which sounds to be about what you gained as well. You have to remember, in German-market trim, the factory power rating for the M120 was 410hp, and the actual real-world number was closer to 440hp. And that's stock. Beginning in 1994, and for all US models from inception forward, they de-tuned it to 389hp to comply with emissions regulations.
So yeah, getting it back to where it was supposed to be is a good thing.
"Veni, Vidi, volo in domum redire." (I came, I saw, I want to go home.)
chriswufgator is offline
post #3 of 27 (permalink) Old 09-11-2008, 08:24 AM Thread Starter
Vehicle: 2006 SL65
It's going for tyres & wheel alignment at the weekend so might try and take some pics of the exhaust then & post them. I haven't had a good look at it myself. I just ask the guys to make it less restrictive and sound better. I think the fitting of cats took the power down to 390 everywhere. I was working back from the dyno - allowing 18% for altitude and 20% for drivetrain sort of worked back to the book numbers at the flywheel. I suppose the only thing that matters really is the comparative real wheel hp. Either way it was a pretty cheap way of adding +15% power (just over USD2100 in total).
post #4 of 27 (permalink) Old 09-11-2008, 08:47 AM
Quoted: 2 Post(s)
I'm pretty sure they always had cats. I think there were other changes that bumped down the power, mostly via programming, but I could be wrong.
post #5 of 27 (permalink) Old 09-11-2008, 08:53 AM
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Quoted: 8 Post(s)
Send a message via Skype™ to msbarsi
chriswufgator the M120 started it's life in Euro spec with 408 BHPs and after a few years they tuned it down to 394 BHPs because (it's a rumor) in 408 spec it was said to blow or spoil the cats after 62,000 miles.
Also rumored is that the figures were higher but no one knows for sure unless they dyoned their cars.
Cheers.
I drive like I stole . . . YOURS
msbarsi is offline
post #6 of 27 (permalink) Old 09-11-2008, 09:01 AM
Quoted: 2 Post(s)
Cheers.
I think they were a little stronger than the factory figures, based on the few dynos I've seen of M120s. Mine pushed 316rwhp on a 100-degree day with a bad radiator and 100c operating temps.
post #7 of 27 (permalink) Old 09-11-2008, 09:13 AM Thread Starter
Vehicle: 2006 SL65
Looking over the numbers and compensating for altitude (~18%). Mine was producing around 325rwhp before the mods. That would mean either drivetrain losses were under 20%, or, more likely and as hinted at, MB understated the numbers. Have also heard that their quoted 0-60 times for both the SL60 & SL600 were also very conservative.
post #8 of 27 (permalink) Old 09-11-2008, 09:17 AM Thread Starter
Vehicle: 2006 SL65
Here in South Africa, I think the pre 96 models didn't have cats as unleaded wasn't available until then. Certainly my 95 SL500 had no cats (and about 10hp more than the 96 model which did).
post #9 of 27 (permalink) Old 09-11-2008, 09:50 AM
Quoted: 2 Post(s)
Driveline losses are normally 18%-20% for an automatic transmission, so if you ran 325rwhp then that translates to a little over 400hp, which is in line with my car and the few other M120 dynos I've seen.
The official numbers are low.
post #10 of 27 (permalink) Old 09-11-2008, 07:21 PM
Tech-Tune's Avatar
Date registered: Feb 2005
Vehicle: SUPERCHARGED Silver Arrow
Quoted: 5 Post(s)
bflannigan, do you happen to know where your current air/fuel is?
Also, do you have any dyno's you can post for us?
I'm asking because I'm curious to see if your tuner richened or leaned your stock mappings.
Thanks
SL55 (R129) 5.7L AMG Kompressor engine, 85mm TB, SLR cam shafts, MAHLE forged pistons, ported heads, long tube headers, full AMG exhaust, AMG P030 Brakes, Quaife LSD
CLS55 (R219) 85mm TB, RENNtech air box, Kleemann Headers, 175mm lower & 84mm upper pulley, 550cc injectors & looped rail, EC dyno tune (528rwhp/598rwtq), and a custom IC reservoir behind my front grill to keep things cool
Tech-Tune is offline
    MILD AIR from A/C DarrenVincent W201 190-Class 3 08-03-2006 10:17 AM
    Turds new 20s' (56k mild warning) Nutz 4 Benz W116 S, SE, SEL, SD Class 40 05-10-2006 01:36 AM
    Mild vibration at idle jvogt W210 E-Class 2 07-10-2005 06:35 PM
    Mild initial mods? tecrekka W124 E,CE,D,TD Class 6 05-28-2003 07:34 PM
    Mild initial mods? tecrekka W124 E,CE,D,TD Class 0 05-24-2003 12:16 PM
