» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 06-29-2008, 02:23 PM   #1 (permalink)
Date registered: Oct 2007
Vehicle: R129 300SL-24 92 m.y.
diagnostic faults codes from CS1000 manual PDF
Hello all
I make a diagnose tool for my SL (1 led with two wires and 1 key with two wires) .
I printed cs1000 manual with faults codes.Is it correct list of faults for my method?
Today i check my car on 16pin diagnostic connector and take next faults:
pin 3(CFI) fault 8 altitude correction signal from ignition control module -???? what is it?
pin 8 (DI) fault 17 -Crankshaft position sensor faulty -????(Engine started and worked prorerly and all correct)
beastia is offline   Reply With Quote
Old 07-01-2008, 11:01 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 300SL, SL500
Since the density of air varies with altitude, the fuel injection system varies the fuel delivery with change in elevation. The sensor for this is in the ignition control unit.
For fault "8" I would check the vacuum line that runs from the ignition control unit to the intake manifold for leaks. If that is okay, then the ignition control unit may be faulty. If your car is running fine, then I would not be concerned if you are unable to correct this fault.
Fault "17" will be generated if the engine is not running at the moment the code is read.
bobterry99 is offline   Reply With Quote
Old 07-01-2008, 11:35 PM   #3 (permalink)
Hello Bobterry
Thanks for help
About fault 17: if i understand correct ,this fault vill be always , when i check a faults on not running engine with ignition is on ?
Old 07-02-2008, 11:46 AM   #4 (permalink)
Yes.
Old 07-02-2008, 01:16 PM   #5 (permalink)
Do i understand it right that fault is normal ?
Old 07-02-2008, 02:12 PM   #6 (permalink)
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500 1993 SL500
bestia, you asked,
"About fault 17: if i understand correct ,this fault vill be always , when i check a faults on not running engine with ignition is on ?"
I think Bob Terry is confirming that when the engine is not running but with the ignition on, this code 17 will be present.
RedLiner is offline   Reply With Quote
Old 07-03-2008, 01:33 AM   #7 (permalink)
in another analogue SL300-24 this fauln not be present
Diagnostic codes barry_s_u W124 E,CE,D,TD Class 24 08-01-2008 11:15 AM
Diagnostic codes for '89 2.6 ppetracca W201 190E, D-Class 0 02-20-2007 10:03 PM
Diagnostic Codes rah0ul W201 190E, D-Class 7 01-28-2007 11:44 PM
Need help, W-220 Owners Manual, Command 2.5 Manual in PDF format pls. ryuhome W220 S-Class 2 09-17-2006 11:45 AM
diagnostic codes! 90-500SL R129 SL Class 2 07-02-2005 07:31 AM
