Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 06-20-2008, 11:48 PM   #1 (permalink)
Date registered: Feb 2006
Vehicle: sl500 and 23 others
Red face instrument cluster question, A/C question, and hydraulic cylinder p/n question
Hi guys,
Can you help me? do you have the part no of 1991 model for the instrument cluster? as
i gave the no that was on my cluster in calstar. they was not able to trace no on my cluster. can you please give the part no for the whole instrument cluster. if also possible is the 2000+ model cluster will be compatible to 91 model? since the new one is digital odometer? if it is possible can you also give me the part no for the higher model type cluster. will I have problem installing them with the old? how do you change from old type to digital odometer? please help thanks.
ac problem. do you also know the parts to replace for this model. as the aircon just turns on when you start the engine.part no please.
hydraulic cylinder for soft top. got the quotation for this already. question is their is left and right side. as I read from this forum their are 12 cylinders. 129 800 21 72, 129 800 21 72, 129 800 20 72, 129 800 16 72, 129 800 02 72. do I have to order 2 of them? one for the left and for the right? for part no 129 800 17 72 and 124 800 02 72 do I have to order only one each? please help me to itemized y do I need 4 pieces 129 800 21 72? please help as I am about to order them. can you give me exact pieces for each part no. thanks hope to hear from you guys soon.
coolkid is offline   Reply With Quote
Old 06-21-2008, 05:42 PM   #2 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: MY00 SL500 SL2
Please read total of twelve cylinders for the hydraulic cylinder p/n's.
Please verify with your parts guy and VIN the following.
4x 129 800 2172
2x 129 800 2072
1x 129 800 1772 (left)
1x 124 800 0272 (right)
2x 129 800 0272
2x 129 800 1672
Note: why would you buy new instead of a rebuild by Dennis Fricken at $30/each plus ship?
Regards, Lynn S.
MY00 SL500 triple black Sport
MY89 560SL triple blue SOLD
MY88 560SL white on tan SOLD
lynns is offline   Reply With Quote
Old 06-21-2008, 06:14 PM   #3 (permalink)
lynns's Avatar
Originally Posted by coolkid View Post
Hi guys,
as i gave the no that was on my cluster in calstar. they was not able to trace no on my cluster.
can you please give the part no for the whole instrument cluster?
if it is possible can you also give me the part no for the higher model type cluster?
please help thanks.
ac problem. do you also know the parts to replace for this model?
part no please?
Please try an 'Advanced Search' of this forum as both of these topics have been discussed several times in the past.
Please check with MBCluster.com -Mercedes Instrument Cluster Repair Homepage
For correct p/n's you can always use your VIN at your local Mercedes Dealership parts counter or try EPC online.
Old 06-22-2008, 10:29 AM   #4 (permalink)
Date registered: Jan 2004
Vehicle: 300SL, SL500
These are electrically incompatible. Later clusters communicate over the CAN data bus while earlier ones do not.
bobterry99 is offline   Reply With Quote
Instrument Cluster question Sergio W210 E-Class 3 12-10-2007 09:36 AM
Yet another question on hydraulic cylinder kyericho R129 SL Class 3 11-17-2006 12:08 PM
Instrument cluster question lushansilva W126 S,SE,SEC,SEL,SD,SDL Class 8 10-06-2006 08:19 AM
instrument cluster question jaymono W163 M-Class 1 08-28-2006 05:52 AM
instrument cluster question jaymono W202 C36 AMG, C43 AMG 0 08-28-2006 04:52 AM
