Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 06-04-2008, 11:34 AM   #1 (permalink)
vignale's Avatar
Date registered: Feb 2008
Vehicle: 1994 SL600 , 2001 Ford Mustang GT , 2003 Chevrolet Trailblazer
Left Turn signal Lights - on all the time.
Hi Guy's, I need some help- I've tried to search all previous topics but couldn't find any one with the same problem as myself.
This morning on my way to work, the Car stopped - when it started at first try- but then with the Left Turn Signal lights on all the time- the bulbs don't blink but are giving steady light. The Right Turn Signal lights blink as normal (while left turn lights still are on.
I Would first have guessed it is a Relay, but then the Right Turn signal would not work as normal would it ?
Could it be a Earthing problem ?
When trying to find the problem I discovered a Relay that was burnt - the Part number is 001 542 9719 - could it have something to do with the Turn signal ?
I also found the reason for the Car stopping, one of the battery connections were loose.
Any suggestions to what is wrong ?
vignale is offline   Reply With Quote
Old 06-05-2008, 09:47 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 300SL, SL500
The relay you mention is associated with one of several possible systems -- none of which is the turn signals. I think your problem is likely the "Combination" relay module. It is the large one among the relays in the area behind the fuses that you have been looking.
Before replacing the Combination module I believe I would disconnect the left-side lamp assemblies at the rear and front of the car and see what happens just to make sure an anomaly with a bulb or wiring isn't causing the problem.
bobterry99 is offline   Reply With Quote
Old 06-06-2008, 06:41 AM   #3 (permalink)
vignale's Avatar
I removed the Bulbs and still the Left turn indicator light is still on.
relay 001 542 9719, seems to be the relay for Auxiliary Fan, Stage II.
The Combination Relay is according to the Russian MB Site number 1298201026, but how to remove it ?
Old 06-07-2008, 10:05 AM   #4 (permalink)
vignale's Avatar
Latest Update, Still can't get a way to take out the Control Unit, and is a bit afraid using force - don't want to break anything.
I tested the hazard lights with Ignition off and all 4 lights blinked at normal speed. In addition to that All Lights on the Dashboard and on switches blinked as well. Does anyone have a clue where to start searching ?
Old 06-08-2008, 12:17 PM   #5 (permalink)
I believe it simply pulls out...
Old 06-09-2008, 09:29 AM   #6 (permalink)
vignale's Avatar
I tried to pull it out and the wires underneath comes with it. I tried to clip the wires off, but didn't manage.
I decided to take it to Bosch to have them to look at it, and a few other problems. I will keep you updated of the result.
Old 06-10-2008, 08:03 AM   #7 (permalink)
vignale's Avatar
And there it goes
There it goes to the Mercedes Dealer in Doha, They were busy and would not be able to touch the car before next week
Old 06-10-2008, 08:28 AM   #8 (permalink)
mame9999's Avatar
Date registered: Oct 2006
Hi vignale
This first time I hear about this problem, any how if you can come to Dammam in KSA I can help you we have here a lot of MB workshop they are professional in repair by computer and the price is possible
Good luck
E200 1990 Sold
E280 1989 Sold
300 CE-24 1991Sold
E320 1994 Sold
560 SEL 1988 Sold
560 SEL 1990
SL600 1993
used in KSA
mame9999 is offline   Reply With Quote
Old 06-10-2008, 08:53 AM   #9 (permalink)
vignale's Avatar
Originally Posted by mame9999 View Post
Hi vignale
Good luck
I might do that and come to Dammam- it's not that far from Doha. Just have to be patient and wait for the Dealer to look at it - time will tell if they are able to fix it. I went first to the Bosch Service, but the Guy in charge today wasn't helpful at all. He told me that his Boss refused to touch any SL500 or SL600 as they were too complicated for them.
Old 06-10-2008, 12:36 PM   #10 (permalink)
mame9999's Avatar
ummm
I Think because they don't know how to repair it that is why they refuse it
And I'm sure they will charge you a lot of money $$$$$$$$$$ but without repair
Becarful at all
Left front turn signal lens broke. ruudvuijsters R129 SL Class 8 04-01-2008 07:12 AM
Bright lights come on every time we use turn signal BatBenz W210 E-Class 2 04-27-2006 03:25 PM
brake deactivates left turn signal englishred W123 E,CE,D,CD,TD,TE Class 1 10-06-2005 07:14 PM
Left turn signal not working... ed W163 M-Class 10 08-27-2005 01:28 PM
left front turn signal detached! alanmb R170 SLK Class 0 04-29-2003 03:47 PM
