» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 05-09-2008, 03:09 PM   #1 (permalink)
marques's Avatar
Date registered: Aug 2003
Vehicle: 1992 SL 500
has any body took apart the abs sending unit?
I tried bleeding my brakes the other day only to notice that no fluid was going thru the LR breaks...all the other wheels were ok. I check the abs system only to find out that no flluid was going thru the unit that supplies the LR brake. Has anyone ever taken apart the abs sending unit? is it easy to do? do you think it could be clogged in there or is the hydraulic system that supples the LR brake broken? do you think i have to buy another ABS system? can any one school me on this?
marques is offline   Reply With Quote
Old 05-09-2008, 05:46 PM   #2 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
When you say no pressure on the left rear did you open the tubing all the way to the split.
Don't replace the ABS till you do that.
Regards,
aam.
aam is offline   Reply With Quote
Old 05-15-2008, 04:45 PM   #3 (permalink)
marques's Avatar
yes, i blew a airhose down the tubing that connects to the left rear brake and it removed all the brake fluid. I know that for a fact because all the fluid blew into my friends face.
Oil Pressure Sending Unit Bluebird W126 S,SE,SEC,SEL,SD,SDL Class 3 09-22-2007 03:30 PM
Gas sending unit ScottinSoCal R/C107 SL/SLC Class 15 05-16-2007 11:58 AM
Temp sending unit khaledfarid R/C107 SL/SLC Class 3 01-27-2007 08:30 PM
Speedometer sending unit? dalek W126 S,SE,SEC,SEL,SD,SDL Class 0 10-08-2006 06:03 AM
Temperature Sending Unit eks3703 R/C107 SL/SLC Class 2 12-15-2004 06:36 PM
