» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 05-15-2008, 05:52 PM   #51 (permalink)
Date registered: Jan 2006
Vehicle: 00 SL500
The gasket goes between the piston and the pad, If you have 2 gaskets per side then put one on the outboard pad between the pad and the caliper.
drags1998 is offline   Reply With Quote
Old 05-15-2008, 06:08 PM   #52 (permalink)
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500 1993 SL500
Gaskets?
Do you mean the thin steel anti squeal shims ?
As Drags has pointed out these must only be placed between the brake pads and the hydraulic pistons located on both sides of the brake calliper.
RedLiner is offline   Reply With Quote
Old 05-15-2008, 06:44 PM   #53 (permalink)
HITWTOM's Avatar
Date registered: Jan 2007
Vehicle: 1985 300CD, '85 500SEC, '97 SL320
OK to clarify I should have said I'm working on her Olds Bravada. Rear pads, the pads came with 2 "gaskets" 1 per side I figure. One side of the gasket is rough, the other smooth. I'm guessing it goes between the piston and the pad, with the rough side towards the pad. It was getting dark and I'm working in the driveway, ran inside and did some searches for information. found some GM forums, but didn't want to have to sign up to find an answer. Figured someone here might have an answer.
Thanks,
Tom
HITWTOM is offline   Reply With Quote
Old 05-16-2008, 02:55 PM   #54 (permalink)
Vehicle: 00 SL500
Are you sure that the rough side was not just a removeable piece of paper protecting the GLUE to hold the "gasket" to the pad???? On any brake jobs that I have done where you have to install the gasket or as I call them "shims" on the pads yourself, they stick to the backside of the pad. Good Luck!!!!!
QUESTION on my recently installed Brake Rotors, Pads, Brake Lines, Brake Flush babyboigsxr W208 CLK Class 5 03-28-2008 10:37 AM
Official Now: My original rear OEM brake pads lasted 74, 500 miles. I bought new OEM pads, a brake AC_ML W163 M-Class 2 02-07-2004 04:25 PM
Anyone had/has Axxis Ultimate brake pads or Pagid Dustless pads before? Andy ::VancouveR:: R170 SLK Class 2 07-12-2003 03:45 PM
Thanks for pics JimB, changed brake pads this weekend no problems, frt pads had more wear than rear Dave L. W163 M-Class 13 02-25-2002 09:48 PM
Anyone replace their brake pads with aftermarket pads? I've seen some ads stating less brake dust. C Brian W208 CLK Class 3 07-22-2000 04:48 AM
