» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-29-2008, 10:21 AM   #11 (permalink)
msbarsi
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Originally Posted by HITWTOM View Post
After reading various posts on this subject, I’m somewhat confused. Everyone seems to suggest the ceramic pads. My question is, can I install ceramic pads with stock original disks? Some say the original disks are vented? Is this all years or only certain years? Some say switch to SA disks, this I believe has to be ’99 or newer? Maybe semi-metallic pads are fine for my everyday driving except for more brake dust. Any comments appreciated.
Hi HITWTOM, I've heard great things about the ceramic pads from many people on the forum so after everything I've read in time I would say go for it. You can freely install them on your stock rotors but since your car has the non Brembo system (the Brembo system was introduced after the last facelift and the calipers are painted in black) you will not be able to install the Silver Arrow drilled disks without a major redo of your braking system but since it costs a kidney I would avoid it. I think you can still find some drilled rotors of the right size for your car which are wonderful to get rid of the heat after heavy braking or spirited driving style (like mine) and in heavy rain because they dry muuuuuuuuch quicker than normal disks.
Hope this helps.
Cheers.
I drive like I stole . . . YOURS
msbarsi is offline   Reply With Quote
Old 04-29-2008, 01:09 PM   #12 (permalink)
chriswufgator
Premium Member
chriswufgator's Avatar
Date registered: Oct 2007
Vehicle: 2001 Mercedes-Benz SL600
Premium Member
Send a message via AIM to chriswufgator
Originally Posted by roncallo View Post
Oh another thing since I replace my rotors and pads together I do not care about how well ceramics wear the rotors. I only wish I could get a set of ceramic pads for my 107's. I've herd ceramics are harder on the rotors than semi metalic. I woulden't know since I cant get them for my car. But I certainly would like a set since I hate dust.
Yeah, that whole "ceramics are bad for the rotors" thing is BS.
In fact, it's the exact reverse. As an example, I have had my new Silver-Arrow rotors and ceramic Akebono brake pads on for about 2 months now, and you can still see the markings from the factory lathe on all 4 rotors...THAT is how gentle the ceramic pads are on the rotors...
With metallic pads, the factory machining/polishing patterns left on the rotors by the manufacturer are usually gone in the first day or two...
"Veni, Vidi, volo in domum redire." (I came, I saw, I want to go home.)
chriswufgator is offline   Reply With Quote
Old 04-29-2008, 10:27 PM   #13 (permalink)
ahmorris
ahmorris's Avatar
Date registered: Oct 2002
Vehicle: '97 SL500 (48k KM) & '00 CLK230 Cab
If anyone has (or decides) to change their SL500 (non sport, non Brembo) stock rotors and pads to drilled and ceramics I'd like to know the source, part numbers and prices.
I've emailed a few people and have found some info but sometimes they say "got front" or "have pads" but not yet found anyone who I could order 4 new rotors and 4 new ceramic pads in one fell swoop.
Cheers
Alan
ps. I agree - for the cost / hassle factor it's easy to replace rotors with pads. I'd maybe not do every time I change the pads (my driving / country isn't too conducive to speeding too much) but perhaps every 2nd or 3rd change depending on the circumstance.
1997 Benz SL500
2000 Benz CLK230 Cab
HONG KONG
ahmorris is offline   Reply With Quote
Old 04-30-2008, 05:26 PM   #14 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Cheers
Alan
Alan
Two years ago.
I replaced the front with drilled rotors made by Zimmerman a good company.
The rear I still have the regulars they are still good and I don't throw things that are practically new.
Check the autodoctorparts.com
They have the front drilled rotors.$ 85
You may send them an email they can order the rear.
The pads I use is the pbr ceramic. $33 front $29 rear.
I am happy with them, low dust stop good.
I do also replace them every 2nd or 3rd depending on condition.
PS .
I don;t know if you are aware the rotors are not directional,
they are the same for both sides.
Regards.
aam.
aam is offline   Reply With Quote
Old 04-30-2008, 06:38 PM   #15 (permalink)
ahmorris
ahmorris's Avatar
Originally Posted by aam View Post
...I don;t know if you are aware the rotors are not directional,
they are the same for both sides...
Thanks. I wasn't aware of that. But front and back are different aren't they? Reason I ask is that when I surf to look for places to buy they have separate parts for front and rear...though when I come to get my credit card out they say can't do entire order! Maybe I need to buy from several places which is a pain re shipping internationally.
Thanks for the websites - will check out. I'm not going to do it right yet. I'm going to get the parts then do in a few months. Since I'm keeping my SL forever I'm happy to spend more to change related parts at the same time so maybe change wheel bearings, repack, rotors, pads etc....I tend to upgrade systems one by one if anything goes on it eg. steering had an issue awhile back, hence replaced most of the steering durables eg. dampers, buses etc, so good for years to come.
Regards
Alan
Old 04-30-2008, 09:55 PM   #16 (permalink)
aam
aam's Avatar
Regards
Alan
What I mean directional rotors I am talking the front can go aether left or right
(not front to rear)
Front pads are not the same with rears. Same thing with the rotors.
I had no problem ordering and paying with credit card.
Not a bad idea on the bearings.
Regards.
aam.
Old 05-01-2008, 05:34 AM   #17 (permalink)
Chicky
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Smile
Regards
Alan
Hi Alan,
No need to go far, I just got my new set of cross drilled Zimmerman front and rear discs, front wheel bearing kits, parking brake shoes from Valiant Auto Parts, Mongkok, HK. Look for Steve, and you can verify if he has for your model year. No sure if he carries the EBC Redstuff or Akebono's, please let me know if he does. I forgot to have my son ask if he carries them.
Hope this helps
Chicky is offline   Reply With Quote
Old 05-01-2008, 05:43 AM   #18 (permalink)
Chicky
Chicky's Avatar
Hi Alan,
Here's the phone number: (852) 2789 9968 (6 lines)
Address: 93 Hak Po St., G/F, Mongkok, Kowloon
Old 05-01-2008, 06:23 AM   #19 (permalink)
ahmorris
ahmorris's Avatar
Originally Posted by Chicky View Post
Hi Alan, No need to go far, I just got my new set of cross drilled Zimmerman front and rear discs, front wheel bearing kits, parking brake shoes from Valiant Auto Parts, Mongkok, HK. Look for Steve, and you can verify if he has for your model year. No sure if he carries the EBC Redstuff or Akebono's, please let me know if he does. I forgot to have my son ask if he carries them. Hope this helps
Chicky
Great advice and thanks for the address / contact. Mongkok is well known for it's Japanese car parts - great find for SL parts. Respect!
I'll definetly go and have a chat with Steve - the rotors were the trickest part for me given weight / shipping costs. Mind if I ask the cost? (feel free to PM me if you're not comfortable giving it out over the airwaves)
I found, and have been in touch, with the EBC dealer in Hong Kong (below) - he's 2 miles away from my new office location so I'm planning a face-to-face chat someday.
中国.香港总代理
DAVID AUTO
33 Wang Yip Street West
13G/F Yuen Long Trading Centre
Yuen Long, New Territories
Hong Kong SAR
TEL: +852 24788227, FAX: +852 24788319, E-MAIL:LUNGHF@NETVIGATOR.COM
Regards
Alan
Old 05-01-2008, 07:34 AM   #20 (permalink)
lynns
lynns's Avatar
Date registered: Jul 2006
Vehicle: MY00 SL500
Originally Posted by drags1998 View Post
Ceramic pads CAN be used with ALL rotors. If the rotors are in good shape, I would just replace the pads. If the rotors are not in good shape then replace the Pads& Rotors.
In fact when I called Akebono USA and spoke with one of there Sr. Technical guys he informed me that it is NOT necesssary to have the rotors 'turned' if they are in good shape. Simply replace the pads and go lite on the braking for the first 300-500 miles if you want to be safe. NOTE: It is very important that you or your mechanic use the anti-squeel paste or you may have a noise. Most noticably when backing up with none going forward.
Regards, Lynn
MY00 SL500 triple black Sport
MY89 560SL triple blue SOLD
MY88 560SL white on tan SOLD
lynns is offline   Reply With Quote
QUESTION on my recently installed Brake Rotors, Pads, Brake Lines, Brake Flush babyboigsxr W208 CLK Class 5 03-28-2008 10:37 AM
Official Now: My original rear OEM brake pads lasted 74, 500 miles. I bought new OEM pads, a brake AC_ML W163 M-Class 2 02-07-2004 04:25 PM
Anyone had/has Axxis Ultimate brake pads or Pagid Dustless pads before? Andy ::VancouveR:: R170 SLK Class 2 07-12-2003 03:45 PM
Thanks for pics JimB, changed brake pads this weekend no problems, frt pads had more wear than rear Dave L. W163 M-Class 13 02-25-2002 09:48 PM
Anyone replace their brake pads with aftermarket pads? I've seen some ads stating less brake dust. C Brian W208 CLK Class 3 07-22-2000 04:48 AM
