» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 05-05-2008, 07:04 AM   #51 (permalink)
Date registered: May 2008
Vehicle: 1991 300SL
I can’t say what to buy…but I can tell you that my Pirelli 6000 are very noisy and loud. I can’t wait to replace them.
dakrri
dakrri is offline   Reply With Quote
Old 05-05-2008, 11:03 AM   #52 (permalink)
Sc00p's Avatar
Date registered: Oct 2007
Vehicle: 2002 SL500 Silver Arrow / 2008 E300W4M
Given the weight of the R129, does it make sense to use XL (extra load) tires? I've had it suggested to me that this is a good idea. It does somewhat limit choices though there are several tires available with XL designation.
Sc00p is offline   Reply With Quote
Old 05-05-2008, 11:04 PM   #53 (permalink)
wayneg's Avatar
Vehicle: 1999 SL500 Sport, Black Opal Pearl, Helios Leather, Pano roof, AMG Aero2 18"Split Rims, Rear Seats
Originally Posted by chriswufgator View Post
Also, how did you get your car lowered? I am assuming your dealer did it with the STAR computer, or did you figure out a way to do it yourself?
My car does not have ADS so its just springs and shocks as far as I know. The original owner had it done. All I was told was the "suspensions been upgraded" The car sits slightly lower than stock as far as I can compare with photos of other cars.
Whist your car is up in the air with the front being worked on I would suggest having the fog lamp bulbs replaced with the xenon gas halogen type, they will then match the colour of the Hid headlamps lamps you have invested so much into recently. I did mine and the lamps are a real pain to remove if you are on the floor, trust me its worth the $20 to upgrade, no more yellow!
wayneg is offline   Reply With Quote
Old 05-06-2008, 04:22 AM   #54 (permalink)
Premium Member
chriswufgator's Avatar
Vehicle: 2001 Mercedes-Benz SL600
Premium Member
Send a message via AIM to chriswufgator
That's a good idea, and the color difference is the main reason I never use the fogs.
What brand did you go with?
"Veni, Vidi, volo in domum redire." (I came, I saw, I want to go home.)
chriswufgator is offline   Reply With Quote
Old 05-06-2008, 05:10 AM   #55 (permalink)
wayneg's Avatar
The cheapest I could find on e-bay, there are thousands to chose from....here`s one $10.50 shipped for a pair eBay Motors: H3 Xenon HID Halogen Superwhite Bulbs Headlamps 55W! (item 130218809575 end time May-06-08 14:27:54 PDT)
(these only fit the AMG fog lights on Sport Models as far as I know)
Old 05-06-2008, 06:03 AM   #56 (permalink)
Premium Member
Premium Member
Alright, just ordered them! Hopefully they will get here in time to be put in at the same time they align my bumper later this week...would be so easy to do once you already have it up on a lift with the front wheels off...
Old 05-15-2008, 07:25 PM   #57 (permalink)
Date registered: Dec 2006
Originally Posted by lynns View Post
I will be very interested to hear back from you on these tires. I have had good luck with Discount Tire with regard to my PS2's. May I suggest that you consider having your tires lifetime balanced every 3K miles and keep the tire pressure set monthly to the numbers posted on your gas cap.
Did you have to special order the tires prior to install?
Did you get a $25-$50 discount for buying all four tires?
Did you utilize there credit card to pay Zero interest?
Any other discounts?
Hi Lynn, To answer your questions. I do plan on taking advantage of the free lifetime balance and rotation offered at Discount tire, the Invo's can also be rotated left to right which should get some extra milage out of them. They had to order the tires....it took three days for them to come in. I was not aware of any four tire discount. I could have gotten the zero percent financing, if I used their card but I did not choose that option. No other discounts were offered. One last point on the instalation, they used "tape weights" instead of those nasty clamp on units. How do they drive? They are awesome, very silent and they really stick in both wet and dry conditions. I have to say I am very happy...so far. Lets see how long these puppys last.
1998 SL500 Sport
nosferatu is offline   Reply With Quote
Old 05-15-2008, 07:54 PM   #58 (permalink)
Premium Member
Premium Member
These are PS2's?
Old 05-15-2008, 10:33 PM   #59 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: MY00 SL500
These are PS2's?
He had a set of Nitto Invo's installed on my 1998 SL500 Sport. "I chose these tires after reading the forums and talking with some people who had bought Nittos. I got them at Discount Tire and can't say enough nice things about the store near me (they even fixed a flat on my girlfriend's Jeep for free, just because I'm a customer) I paid $982.64 for 2 245/40ZR-18 and 2 275/35ZR-18 I will get back to everyone with a follow up as to how these tires perform and last"
Regards, Lynn
MY00 SL500 triple black Sport
MY89 560SL triple blue SOLD
MY88 560SL white on tan SOLD
lynns is offline   Reply With Quote
Old 05-16-2008, 05:50 AM   #60 (permalink)
Premium Member
Premium Member
Oh, ok, I thought I missed something.
Also, I solved my rubbing mystery. I had the stealer look at it while it was in getting its new headlight put in, and they say the car was designed for either PS2's or ContiSport 2's, and that the sidewalls on the All-Season version of the Pilot-Sports are much higher than what would be spec, and that the tread is also raised significantly compared to the summer versions.
So, even though I technically have the correct tire sizes, apparently I don't *really* have the correct sizes. The tech said this is why my fronts were rubbing if the wheel was in the lock position. He also said it's doing it equally on both sides, but I just thought it was the one side because that's what I was hearing when I drove. The SA showed me another R129 they had in, and he was right. The tires showed the same exact sizes as mine printed on them, but the summer PS2's that one was wearing had sidewalls that were probably half as tall as the all-season Pilot-Sports that mine wears. There is a definite difference.
Rumour is the Tire pressure sensor is in all cars whether you ordered it or not... ianx, manchester R171 SLK Class 10 04-28-2005 12:10 AM
Softer riding hi-perf tire for '98 SL500sport? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-26-2002 06:22 AM
Tires ML500, softest ride... ar W163 M-Class 1 11-17-2001 01:45 PM
The new tire test cars for thew Tire Rack @dmnLuke@tirerack R170 SLK Class 4 05-11-2001 10:28 AM
The new tire test cars at the Tire Rack Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 05-10-2001 11:14 AM
