Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-04-2008, 10:49 AM   #1 (permalink)
Date registered: Jun 2007
Vehicle: 1992 500 SL
Cool Convertible Top Material Choices
I have a 1992 500SL and after viewing the 12 or so videos I found thanks to this Forum, I've decided to take a shot at changing the top myself.
The videos seem pretty good although after viewing them a number of times, I have a few questions. I digress for the moment. My question for this thread is, which fabric should I use? I see the original "German" fabric, "Sonnedecke", and "Stayfast".
The Sonnedecke looks comparable to the German but $100 cheaper.
I don't know anything about the Stayfast. Any info on what you know, liked, disliked etc. about any of these choices would be greatly appreciated. Also if anyone has particular experiences with installation and/or manufactures of tops that they would like to share, I'll take anything I can get.
Thanks in advance. Phil
Phil DeSimone is offline   Reply With Quote
Old 04-04-2008, 01:17 PM   #2 (permalink)
Premium Member
chriswufgator's Avatar
Date registered: Oct 2007
Vehicle: 2001 Mercedes-Benz SL600
Premium Member
Send a message via AIM to chriswufgator
Can't go wrong with Haartz (the manufacturer of the 'Stayfast' line). They are top-quality (excuse the pun).
"Veni, Vidi, volo in domum redire." (I came, I saw, I want to go home.)
chriswufgator is online now   Reply With Quote
Old 04-04-2008, 03:47 PM   #3 (permalink)
Vehicle: 1996 500SL
Phil,
I decfided to do my own as well and I just finished it last week. I am happy with the material and how it came out, but I made a mistake and I have to take it into the dealer to have the top and windows synched.
I bought a top from egbay and the guys name was David Daoud email daviddaoud3000@yahoo.com for uner $400. The material is as good as the original or I can't tell the difference. I think he said it is German Canvas. The workmanship and cut of the top was very good. He also has seats for the SLs as well.
The local top guy wanted $1500. The Stealer wanted $2300. I decided I would tackle it. The video is pretty good and directions come with the top. You need to review both together. It will take longer than you think. It took me 7 hours to take the old one off and get the old glue off. Make sure you get all the old glue off or it will not be a smooth finish. Then I had my father help me for two days on the weekend put the new top on.
The two key points are getting the seam on the front part positioned correct. The front bow and listing stitch are the reference points when gluing the top to the header bow. I screwed up here and had to pull it off and redo it.
The other key is making sure that you cut out areas or prepunch holes for both the back bow which gets several layers of canvas and the side flaps where they attach to the vertical piece by the door windows(these must be cut away). The video showed simpy punching the bow, but what I found was using a little longer sheet metal screw worked good in order to find the hole in bow and be able to snug it up.
Good luck. Take your time. I watched the video several times even when I was installing the top.
Marv
MarvClott is offline   Reply With Quote
Old 04-16-2008, 01:36 PM   #4 (permalink)
Date registered: Sep 2007
Hi Marv,
Could you tell me how can get the video that show how to replace soft top.
Thanks
Mark
Markcooper is offline   Reply With Quote
Old 04-17-2008, 08:10 AM   #5 (permalink)
Vehicle: 1996 500SL
Originally Posted by Markcooper View Post
Hi Marv,
Thanks
Mark
I found them in the stickies at the top of the first page of the fourm. There are videos for doing the top and videos for taking apart the console, the doors and a couple of other things. They are vey helpful. I had a little bit of a problem figuring out how to download them so I could have the on my computer, but somehow I managed to do that. Don't ask me how because I can't remember.
How to reset my convertible top! San Diego Al R129 SL Class 2 12-02-2006 02:06 PM
Fluid from convertible top drdewrag R129 SL Class 2 08-18-2006 04:17 AM
Convertible Top Too Tight Ebie R/C107 SL/SLC Class 5 08-11-2006 11:42 AM
What is the material on the roll bars (exterior) and rear back deck (when top is down)? DaveS R170 SLK Class 4 06-25-2003 04:00 AM
care for convertible top shuf W208 CLK Class 2 01-27-2003 05:51 PM
