Charcoal canister shut-off valve? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-28-2008, 06:08 PM
Dan Tomlinson
Guest
Posts: n/a
Quoted: Post(s)
I have a 1994 SL320 with a check engine light for code PO441 (Purge control valve function), which I got from the MB dealer that I had look at the problem. I have replaced the purge valve as I believe it had died. It was full of carbon particles from the canister. The new valve I installed also had some particles in it after a short time, but I cleaned it and it is still OK (I think). I have spliced in a fuel filter to keep the particles out for now. When I blow into the tubing that goes to the canister from the Purge valve I can hear a rushing sound coming from somewhere below the Purge valve. I have checked the canister and the three tubes appear OK as does the canister. I do not hear any leaks in that area. I think the sound is probably coming from, or near, the canister shut-off valve, but I don't know where it is located. Can anyone tell me where it is and how do I access it?
post #2 of 3 (permalink) Old 03-29-2008, 11:07 AM
Moving On
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Silver
Quoted: 9 Post(s)
Welcome to the R129 Forum. Check FUEL SYSTEM>CLOSED FUEL-EVAPORATION-CONTROL SYSTEM
Or take a look at these drawings and see if they help at the Russian parts site.
lynns is offline
post #3 of 3 (permalink) Old 03-29-2008, 02:04 PM
Dan Tomlinson
Guest
Posts: n/a
Quoted: Post(s)
Thanks lynns, but they really don't show where these lines are on the car. For instance, one of the lines coming off of the canister goes into a grommet and through the frame towards the engine but I can't see where it comes out on the other side. I think that is where I can hear rushing when I blow into the tube that comes fron the Purge valve. I have a diagram that shows a canister shut-off valve but I have no idea where it is located. I also don't think I should be able to blow or suck air through the canister without any resistance. Am I correct?
DIY Charcoal Canister & Valve CambridgeMA W210 E-Class 7 08-09-2011 01:13 PM
Evap charcoal canister CambridgeMA W210 E-Class 0 02-01-2008 04:37 AM
1997 S420 Charcoal canister and valve location aljabari W140 S-Class 0 09-14-2007 06:39 PM
charcoal canister removal NüR-SPEC W126 S,SE,SEC,SEL,SD,SDL Class 7 01-26-2007 09:51 PM
Charcoal canister tknghk R170 SLK-Class 5 03-16-2006 11:02 AM
