Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 03-20-2008, 05:42 AM   #1 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, S420
Where is the CPS (Crankshaft Position Sensor)?
I've seen the CPS on the E320 (W210) but couldn't find it on the R129. It doesn't seem to be where it should/would be. Does anyone have a picture of where it is? Thanks a million.
lnguyenh is offline   Reply With Quote
Old 03-22-2008, 08:48 AM   #2 (permalink)
Date registered: Aug 2007
cps
i can't find my picture of it, but, on my 90 sl500 if you are facing the front it is at the end of the valve cover (kind of to the right of middle at the front of the engine. It has a coax type cable attached to it that runs over to the fender well. that cable was cut on mine and it cost me a wiring harness to repair. 2k. hope this helps...
jwh1951 is offline   Reply With Quote
Old 03-22-2008, 08:50 AM   #3 (permalink)
cps
previous reply was for the camshaft position sensor. sorry for the mistake..
Old 03-22-2008, 10:44 AM   #4 (permalink)
RoadKing's Avatar
Date registered: Sep 2007
Vehicle: 1992 500 SL ; 2001 BMW 525i Sport, 1998 Harley Road King
I think the Cam Shaft Sensor is on the back of the engine. Either on the rear of the block or the bellhousing. Replacing it is not real easy.
Mike
When you turn your car on, does it return the favor?
'92 500 SL
RoadKing is online now   Reply With Quote
Old 03-24-2008, 06:43 AM   #5 (permalink)
lnguyenh's Avatar
I found and replaced it. It was hard to see and much harder to replace.
Old 03-24-2008, 08:04 AM   #6 (permalink)
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500 1993 SL500
Now that you found it, where is it?
RedLiner is online now   Reply With Quote
Old 03-24-2008, 09:30 AM   #7 (permalink)
lnguyenh's Avatar
I was told where it was but took me 6 months to finally see it !!! Even if I take pictures now, it's hard to see.
Standing on the driver side front fender (against the front wheel) with the engine cover off. The CPS is at the back of the engine. It should be beneath the MAF (intake) and above the transmission. Its end should point right at you as you look at it. (I always thought it would point to the firewall of the car and that was why I could never find it). Hope this helps.
FS: Crankshaft Position Sensor 3199cc W208 CLK Class 1 08-16-2008 07:33 AM
Removing the crankshaft position sensor (CPS) mikevernon R170 SLK Class 7 02-18-2008 11:54 AM
ML320 CPS – Crankshaft Position Sensor failure & fix jangr320 W163 M-Class 0 05-17-2005 04:24 PM
Crankshaft Position Sensor stanbrosen W124 E,CE,D,TD Class 2 02-27-2005 12:06 AM
Crankshaft position sensor GREEKCS W126 S,SE,SEC,SEL,SD,SDL Class 2 01-13-2004 08:52 PM
