Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 02-14-2008, 07:31 PM   #1 (permalink)
oklahoma's Avatar
Date registered: Dec 2007
Vehicle: 2005 SL55 Silver over Ash, 2000 SL500 Burgundy over Tan, 1999 Viper Black on Black, other FAST cars!
Loose Rearview Mirror....
My rearview mirror is slightly ajar, is there a way to tighten it? It doesn't need replacement just tightening. 2000 SL500
oklahoma is offline   Reply With Quote
Old 02-15-2008, 11:23 AM   #2 (permalink)
Date registered: Jun 2006
Vehicle: 1997 SL500
Yes there is. Same thing happened on my 1997 SL500. You have to remove the back plastic cover (can't remember if there are any screws involved), you'll see when you look @ it from the back. I remember that it was not difficult- 20-30 minutes tops and on a scale of 1 to 10 for difficulty, it is a 1 or a 2 to fix. Just be careful when you remove the cover, not to pull to hard because of the circuitry and wires. After you get it apart, carefully pull out the ciruit board. There is a nut on the inside which connects the mirror to the shaft, simply tighten the nut with a pilers/wrench. Hope this helps
JohnDB is offline   Reply With Quote
Old 10-18-2008, 08:39 PM   #3 (permalink)
lincoln's Avatar
Date registered: Oct 2005
Vehicle: 97 SL500
Sorry to dredge up an old thread but my 97 SL500 mirror is loose too, so I took it apart today to do some exploring only to find my mirror is tight at the ball joint/shaft inside the mirror housing but the shaft into the header is loose. I can't figure out how to "get at" the mounting point or if it can even be tightened???
97 SL500 - Silver/Ash, 19" ASA ST2, Passport SRX stealth install, Clifford G5, Llumar Clear Bra, 20% Tint, Bilsteins.
99 Chevy Silverado ECSB LT Z71 - very modded
08 GMC Sierra Denali - White/Ebony, lots of mods
03 SL55AMG - Silver/Charcoal Pano - Dealership demo
lincoln is offline   Reply With Quote
Old 10-18-2008, 11:37 PM   #4 (permalink)
Premium Member
mikedan's Avatar
Date registered: Oct 2008
Vehicle: 1995 SL600 blk/blk
Premium Member
+1 My rearview mirror (1995 SL600) does a little dance every time I accelerate or brake. I'm going to take it apart over the next few days. Thanks for the info Oklahoma. Let's hope the nut is the problem. I would love a simple resolution for a change!
mikedan is offline   Reply With Quote
Old 11-02-2008, 09:15 PM   #5 (permalink)
Rocco Vespe's Avatar
Vehicle: 1999 SL500
carefuly pull it down. it is a breakaway in case of an accident. tighten the big nut under it.
RR
Rocco Vespe is offline   Reply With Quote
Rearview Mirror??? fata1ity W124 E,CE,D,TD Class 4 01-11-2008 08:22 AM
Rearview mirror very loose, or broken sanginman W210 E-Class 6 11-20-2007 05:04 PM
Rearview mirror came loose MJ50 W163 M-Class 1 11-06-2007 12:57 AM
Outside Rearview Mirror Benz06 W203 C-Class 1 04-14-2006 10:53 PM
Rearview Mirror hansduker W163 M-Class 2 10-17-2005 01:11 PM
