» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 12-23-2007, 03:01 PM   #11 (permalink)
Date registered: Feb 2005
Vehicle: 96 SL500, 97 E420,
Send a message via Yahoo to gqmagic
Best thing is to get a charger that has a 2 amp trickle for when you aren't running your SL for extended periods. A good charger about $40 on sale is quite a bit cheaper than having to diagnose, repair, replace costly electronics.
gqmagic is offline   Reply With Quote
Old 12-24-2007, 03:15 AM   #12 (permalink)
Date registered: Oct 2007
Vehicle: R129 300SL-24 92 m.y.
Hello again
I decided to charge up my battery separately on extended battery charger
This method doesn`t have a risk of damage Ecu and oter devices on car.
This method worked 100%
beastia is offline   Reply With Quote
Old 12-24-2007, 03:25 AM   #13 (permalink)
You can jump start a merc. but you really should have a surge protector installed first. AKA anti-zap.
Do a search, there are lots of post's about this item.
Antizap Auto Surge Protector - OTC3386
livefreeordie is offline   Reply With Quote
Old 12-24-2007, 07:37 AM   #14 (permalink)
Prvteye's Avatar
Date registered: Apr 2007
Vehicle: 1999 SL 500 80,000
Thanks for the link, I,m ordering one today was thinking I might mount it in in rather than clip on.
Prvteye is offline   Reply With Quote
Old 12-24-2007, 12:08 PM   #15 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: 2000 SL500 Sport
What you want is the 12 Volt Antizap Permanent Mount
at STANDARD Industrial & Automotive Equipment, Inc.
It look like this could save us ALL a bunch of trouble if we had one installed!
lynns is offline   Reply With Quote
Old 12-24-2007, 12:23 PM   #16 (permalink)
lynns's Avatar
Look what this guy did with his battery!
Old 12-24-2007, 12:56 PM   #17 (permalink)
Prvteye's Avatar
Here's some more at http://www.naauto.biz:8080/naauto/or...09/product1125 or
AntiZap / Booster Cable Upgrade Kit, 12-volt, with LED control [32-100] - $17.48 : Starting Equipment or
Antizap $13.95
AFTER JUMP START? FASTRMK700 W202 C-Class 3 10-09-2007 01:49 PM
Jump Start? FASTRMK700 W202 C-Class 2 10-08-2007 12:50 PM
Jump Start 380 Sl osdesierto R/C107 SL/SLC Class 4 07-03-2007 01:35 PM
Jump Start with SLK? masterdog R170 SLK Class 3 05-30-2007 07:13 AM
jump start? pepito W123 E,CE,D,CD,TD,TE Class 8 02-05-2004 07:18 AM
