Headlight sockets melted. What's the cause; how to replace? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-26-2007, 09:04 PM Thread Starter
Date registered: Sep 2006
Noticed my headlight low beams cutting in and out. Wiggling the light socket would cause them to go on and off. Once I pulled the bulb out (difficult), I could see melted plastic that once formed the female sockets. Happened on both headlights. Anyone know what would cause this on a 97? How are the sockets replaced since the wires appear to be formed into the socket and the wires go off through the headlight assembly into the great unknown?
SLer
97 SL500
Orlando
SLer is offline
post #2 of 13 (permalink) Old 11-26-2007, 09:57 PM
ahmorris's Avatar
Date registered: Oct 2002
Vehicle: '97 SL500 & '01 ML320
Bit tricky to know if you are not the only owner.
Have seen something similar when people have modded the original bulbs for extra-bright light bulbs which have too high a wattage rating, get too hot and therefore melt the housing.
Maybe somone realised what was happening, or didn't like and reverted back to original bulbs before mountings useless thereby looks like stock bulbs but these weren't causing the problem.
Alternatively, it could be just gremlins...
1997 Benz SL500 (R129)
2001 Benz ML320 (W163)
HONG KONG
ahmorris is offline
post #3 of 13 (permalink) Old 11-27-2007, 01:51 AM
Administrator
RedLiner's Avatar
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 415 Post(s)
It's usually a bad electrical contact that causes heat to be generated and the fact that the low beams were intermittent would back this theory up.
If the bulb sockets aren't too far gone I would check and clean the contacts also the bulb's soft lead (as in Pb) contacts as well as checking the spring pressure which is what holds the contacts together.
RedLiner is online now
post #4 of 13 (permalink) Old 11-27-2007, 06:53 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 172 Post(s)
Had the same problem, poor design.
Wires/connector, to thin.
But it is easy to solve.
Cut some small copper strands from thin wire stuff them in the connector holes,
and cut them, check for shorts.
Then push the bulb in.
It is been over a year.
Keeps on ticking.
Regards,
aam.
aam is offline
post #5 of 13 (permalink) Old 11-27-2007, 08:22 PM
TheVpwr's Avatar
Date registered: Aug 2004
Vehicle: SL600 S420
I have the socket...$20 shipped to US
DRIVE IT LIKE YOU STOLE IT!!!
TheVpwr is offline
post #6 of 13 (permalink) Old 11-27-2007, 11:08 PM
old_s13's Avatar
Vehicle: N/A
Keeps on ticking.
Regards,
aam.
Well, kept on ticking until we discarded the older headlamps in favor for the xenon headlamps! :-)
AFAIK, this problem should only occur on US-spec vehicles which use the DOT headlamps. These headlamps use the HB1 bulbs which have connector pins barely adequate for 55 watt bulbs. As AHMORRIS stated, if anyone has tampered with the headlamps and attempted to use an overwatt bulb, they will often cause damage to the headlamp's connector.
You can shim the connectors which can work, but ultimately the connector should be replaced.
- Mike / ClearCorners.Com
old_s13 is offline
post #7 of 13 (permalink) Old 12-10-2007, 04:16 PM
sd_cowboy's Avatar
Date registered: Dec 2007
Vehicle: 1997 SL320, 2011 Panamera 4
R129 Headlight Sockets
TheVpwr
If you still have one I'm interested to buy it.
sd_cowboy is offline
post #8 of 13 (permalink) Old 12-13-2007, 08:43 PM
old_s13's Avatar
Vehicle: N/A
FYI, you may want to check with the folks over at Susquehanna Motorsports Home Page - they're a great company and should be able to supply OE connectors for that application.
Like I said before though, be warned... the optic performance of the US-spec halogen headlamps is rubbish.
old_s13 is offline
post #9 of 13 (permalink) Old 12-13-2007, 08:58 PM
Isaac Collins's Avatar
Vehicle: 1998 Mercedes Benz SL 500
On my 98 I had the problem of the left beam not working at all, the entire left side actually, I rewired the left headlights to the rights and got a 40 fuse instead of 25, just be sure to keep the wires seperated from each other once there connected.
Isaac Collins is offline
post #10 of 13 (permalink) Old 12-14-2007, 12:48 PM
old_s13's Avatar
Vehicle: N/A
i wouldnt recommend upping the amperage of your fuse unless you're looking for trouble. you want to fix the problem and not increase fuse rating, especially since your wiring is still the same gauge!!!
something like this could cause a fire...
old_s13 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
How to replace headlight bulb msmmgr R170 SLK-Class 4 11-29-2010 01:13 AM
Headlight female connector melted! easy fix? bc2885 General Mercedes-Benz 8 03-22-2007 01:27 AM
How to replace a little headlight bulb? okiloveu W210 E-Class 5 11-24-2006 12:09 AM
Replace C240 headlight royus W203 C-Class 1 09-06-2006 07:15 AM
extra headlight sockets brandx006 R170 SLK-Class 8 04-18-2003 08:40 AM
