Voice Activation System Commands List - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 11-24-2007, 03:59 PM Thread Starter
Sc00p's Avatar
Date registered: Oct 2007
Vehicle: 2002 SL500 Silver Arrow / 2011 Jaguar XJ
Quoted: 5 Post(s)
Well, I just discovered that my new-to-me SL has a voice command system. I have serached through the manual and can find nothing explaining how to use it. I have searched the forum using every combination of the words in the subject line and still can't find anything. I pulled back the stalk on the right side of the steering column and heard a female voice. I determined I could change the CD track, but that's all I've tried so far. Does anyone know of a resource to give a list of commands? On a related note, should there have been a separate audio system manual with the car? If so, does nayone have a copy saved they could email to me? Thanks for the help.
Sc00p is offline
post #2 of 16 (permalink) Old 11-25-2007, 07:35 AM Thread Starter
Sc00p's Avatar
Quoted: 5 Post(s)
Well, I played around with the system last night and discovered that by pulling the stalk towards the driver it activated the system. I said 'Help' and the system asked for which component I wished to have more info - Radio, CD, Phone or WB. Saying one of the 4 provides a list of commands that can be spoken. So, I was able to switch from CD to radio by pulling the stalk and saying 'radio'. It takes you to the last tuned station. I then said 'AM' and it switched to the AM band. I could then call up a specific frequency or go to the next pre-set. It was as easy as saying 'frequency six-eighty'. Like wise while listening to a CD, I could go to the previous or next track, ar call up a specific track. Very neat indeed. My BMW 525i has voice-activation, but as I do not have Nav, it only functions for the bluetooth connection to my Razr phone.
Quite a handy safety feature really, the ability to control the audio system without having to look down at the controls. The only thing I haven't found is the ability to change volume. I'll have to keep playing with it.
Sc00p is offline
post #3 of 16 (permalink) Old 11-25-2007, 08:33 AM
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Quoted: 8 Post(s)
Send a message via Skype™ to msbarsi
Hi Sc00p try to pull the stalk and say ......volume up ........or volume down.
Maybe it works....
Cheers.
msbarsi is offline
post #4 of 16 (permalink) Old 11-25-2007, 01:47 PM Thread Starter
Sc00p's Avatar
Quoted: 5 Post(s)
Maybe it works....
Cheers.
I tried that last night - no success. I think I'll continue to experiment with it - there are probably more things I can do than I realize. The 'help' menu was certainly helpful.
In the meantime, if anyone has knowledge of the system, I'd be grateful for a mnual of some sort. Cheers,
Sc00p is offline
post #5 of 16 (permalink) Old 11-25-2007, 05:29 PM
Moving On
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Silver
Quoted: 9 Post(s)
In the meantime, if anyone has knowledge of the system, I'd be grateful for a manual of some sort. Cheers,
I was unable to find a manual or flow chart that explains what voice commands to enter into the system but it looks like you are aware of the 'Help' command. Please see the attached PDF's.
File Type: pdf Voice_Activated_System_servicebulletins_p_i_82_64_137a.pdf (956.0 KB, 1289 views)
File Type: pdf Digital_data_bus-D2B_GF82.00-P-0001A.pdf (42.1 KB, 618 views)
lynns is offline
post #6 of 16 (permalink) Old 11-26-2007, 03:52 AM
Date registered: Oct 2005
Vehicle: SL500 Silver Arrow
What audio system do you have for the car? European models weren't available with any sort of voice activated commands - I can't see the US being any different as the instrument cluster doesn't even allow programming for the APS30 Nav system.
stats007 is offline
post #7 of 16 (permalink) Old 11-26-2007, 08:37 AM
Moving On
lynns's Avatar
Quoted: 9 Post(s)
'Push to Talk' lever
Because he is a new owner of the car it looks like only another U.S. SA owner would be able to answer your question. But here is a picture of the 'Push to Talk' lever. Do you have this lever on your SA?
Name:	Push to Talk Lever.JPG
lynns is offline
post #8 of 16 (permalink) Old 11-26-2007, 06:22 PM
newbie88's Avatar
Date registered: Oct 2006
Vehicle: 1988 300E & 1995 E320 Coupe & 1998 E320 & 2001 SL500
Try this:
Wolfgang's ML Page: Mercedes voice control - Linguatronic
and the manual for 2001:
http://phdwebsite.powerpulse.cc/VCM/...M%20Manual.pdf
newbie88 is offline
post #9 of 16 (permalink) Old 11-26-2007, 06:53 PM
Moving On
lynns's Avatar
Quoted: 9 Post(s)
Originally Posted by newbie88 View Post
Thanks. This 2001 Voice Control Manual.PDF is now a part of the 'R129 Owners Manual' sticky.
lynns is offline
post #10 of 16 (permalink) Old 11-26-2007, 07:15 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 392 Post(s)
Maybe it's a good thing that most of us don't have voice activation fitted.
About three weeks ago I again nearly lost the car around a tight bend and for the second time since owning the car heard the metallic grating noise of the roll bar deploying.
I don't know what a voice recognition system would have made of the comment
RedLiner is offline
    Voice Activation System (UK Spec) kenzed R171 SLK-Class 14 04-15-2007 02:06 PM
    Voice Commands ci2800 W203 C-Class 0 05-27-2005 05:36 AM
    OK new question on NAV voice commands (2001 model only) Stewart W163 M-Class 3 04-09-2002 07:47 PM
    Anyone has the Voice Activation System? 3starpwr W163 M-Class 6 11-15-2001 09:35 AM
    voice activation system wildfire W163 M-Class 0 09-06-2001 03:16 PM
