winding noise after 2-3 mph + - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 07-24-2007, 07:53 PM Thread Starter
Thierry2000clk's Avatar
Date registered: Jun 2005
Vehicle: 1997 SL500; 2000 CLK320
Send a message via MSN to Thierry2000clk
Question winding noise after 2-3 mph +
This is a real mistery, my 97 SL500 has this winding mid pitch sound coming from I think the front driver side area (sounds like behind the cluster).
I only happends when, the car hits 3 mph + and continue without changing pitch or very litle with speed variation. Even does it at 200 mph +
Tought it could be the spedo cable, but heard that all SL came with electronic spedo.
Lifted the car on all 4 and turned every wheels even started the car and placed in D and started spining the wheels and to my surprise no sound. Now I see that the sound only comes when the car is drive going more than 2-3 mph on the road.
Tought could be bearing but when turning the wheels when up in the air no sound at all. This is no a very loud sound but enuff for a new pasenger to notice and a reg driver to forget about it.
Anybody had this situation before,
Thierry2000clk is offline
post #2 of 20 (permalink) Old 07-24-2007, 08:11 PM
tjobeid's Avatar
Date registered: Dec 2006
Vehicle: 1995 sl 500 red/black w/renntech wheels
Send a message via AIM to tjobeid
you may want to take a look at your weather strip , sometimes it can be damged and lets air in , also make sure your window close all the way.
1995 SL500 red / black w/ ]RENNtech wheels. For sale
1992 sl500 red/tan 154k. 4sale also best offer.
Looking for 1999-2002 500sl or 93-1999 sl600
tjobeid is offline
post #3 of 20 (permalink) Old 07-24-2007, 08:14 PM Thread Starter
This noise is present in all situation windows / top up or down.
post #4 of 20 (permalink) Old 07-24-2007, 08:17 PM
tjobeid's Avatar
put the car on a lift , all 4 wheels off the ground and start the car , give it a little gas and roll it to about 25 mph if there is not noise its just the wind coming into the car from the weatehr strip , if there is nois even on the lift , im clueless sorry.
tjobeid is offline
post #5 of 20 (permalink) Old 07-25-2007, 08:42 AM
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 223 Post(s)
You can't be certain your wheel bearings are good by just spinning it while the car is on the lift. I have had experience with faulty wheel bearings that were quiet when it carries no load/weight.
You may consider having your wheel bearings/spacers visually inspected and measured to determine if the play (movement tolerance) is within spec., re-pack with appropriate lubricant, and torque as specified.
Good luck.
edcarls is offline
post #6 of 20 (permalink) Old 07-25-2007, 04:20 PM Thread Starter
I'm going to trie your sugg, I'll let you know if the noise stops after the bearing job. Were could I get the exact specs and details on lub and work on hand.
post #7 of 20 (permalink) Old 07-25-2007, 05:32 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 408 Post(s)
The wheel bearing info is here V12 Uber Alles, Doing the Front Brakes in a W140 Mercedes Benz
Just to add I did mine and repacked with High temperature bearing grease
RedLiner is offline
post #8 of 20 (permalink) Old 07-25-2007, 06:38 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 172 Post(s)
For us who have been around the block a few times.
Old school technology.
How to check fast .
Wheel bearings, struts,shocks,& mounts,tie rods ,half shafts
etc.
Front and rear suspension problems, if you are good.
You drive the car on an empty lot or something like that, about 20 mls per hr.
Move the steering wheel sharp left then sharp right a few times .
Be Carefull you don't want to throw the car in to a drift.
Listen for bearing noise, etc.
What you are trying to do, is load and unload the suspension half car at a time.
When left side or right is compressed (down) and noise is there,
You found the bad side.
Regards.
aam.
aam is offline
post #9 of 20 (permalink) Old 07-26-2007, 02:29 AM
Date registered: Jul 2005
Vehicle: Black SL 500 1994
Does it purr..?
ErikFinn is online now
post #10 of 20 (permalink) Old 07-26-2007, 08:18 AM
Quoted: 223 Post(s)
How to check fast .
aam.
Another "old school" method of testing wheel bearing is to lift your car and hold your tire with one hand on top and the other hand on the bottom. Then shake the tire by pulling the top while pushing the bottom and pushing the top and pulling the bottom repeatedly. You can tell your bearing is shot or need adjustment (shim) if you feel movement between the hub and the spindle.
If you can't feel any movement while shaking the tire from top to bottom, hold the tire with one hand in front and one hand at the back and shake it repeatedly. With this hand position you can observe your drag link for unusual (loose) movement and feel the movement between the wheel bearing/hub and the spindle.
If you can't feel any unusual movement in any hand position, your wheel bearing is ok and you may only need to re-pack and torque the main wheel hub nut to a tolerable play within spec.
You can apply the same procedures on your rear tires to test the bearings and other suspension components.
edcarls is offline
    Wind noise 40+ mph, is this normal? 00ML Keith W163 M-Class 17 08-19-2008 01:32 PM
    Whinning noise 40-45 mph, diffenetial Mac90 R170 SLK-Class 3 08-16-2006 10:24 PM
    Winding noise from power steering? TBenza W163 M-Class 4 09-24-2005 05:05 PM
    over 60 mph noise cass5063 W163 M-Class 7 03-09-2005 03:33 PM
    Noise above 40 mph Gene R170 SLK-Class 1 06-03-2002 12:44 PM
